Mac mini Dual Drive Kit
  • Mac mini Dual Drive Kit / Upgrade Bundle
  • Mac mini Dual Drive Kit / Part Only
26,99 $
26,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Artikelbeschreibung
Beschreibung
Beschreibung
Your Mac mini supports two hard drives—get the kit with the cable, hardware, and tools you need to make the upgrade. No need to pay the Apple premium for an expensive Mac mini server when you can do it yourself and save.
Kit Inhalt
Kit Inhalt
  • SATA Hard Drive Cable - connect your new drive to the logic board
  • Mounting Grommets - soft rubber grommets protect and dampen vibrations from your new hard drive
  • Mounting Screws - four set screws to safely secure your new drive
  • Logic Board Removal Tool - specialized for the Mini's unique logic board
  • Spudger - ESD safe tool for disconnecting cables, poking, and prying
  • Bit Driver
  • 4 mm Precision Screwdriver Bits:
    • Torx T8
    • Torx T6
Kompatibilität
Mac Mini Late 2012
2.3 GHz (Quad i7)
2.5 GHz (Dual i5)
2.6 GHz (Quad i7)
Mac Mini Mid 2011
2.3 GHz (Dual i5)
2.5 GHz (Dual i5)
2.7 GHz (Dual i7)
Reparatur-Geschichten
Mein Problem
I had a 250GB SSD as ordered from Apple. Needed more space. Decided to add a Crucial 1TB drive in the bottom bay.
Meine Reparatur
I had bought another drive cable online and it didn't work at all. Sorry I didn't go with IFixIt. The IFixIt cable worked perfectly. Now if I could only get the Mac (Disk Utility) to buil . . .
Mein Problem
to make it faster
Meine Reparatur
smoothly
Mein Rat
fine
Mein Problem
Wanted to add an SSD so it would have faster start up times.
Meine Reparatur
Perfect! It was so easy using the online instruction guide that the procedure was a breeze. I loved how all tools that I needed were provided. A++
Mein Rat
Look at the comments within the instruction guide. They help out a lot. Under each description . . .
Mein Problem
needed to upgrade my macmini main drive from 500gb to 1tb
Meine Reparatur
it was easy. instructions were accurate.
Mein Rat
have a clear magnetic sheet next to you to keep track of the screws.
Mein Problem
Boot camp was being a little troublesome with just the stock drive. Certainly enough space, but after upgrading to High Sierra OS/X was getting a little more finicky than usual with the whole dedicated bootcamp partitioning thing. After having tried a few other more conventional things, DVD drives r . . .
Mein Problem
500GB spinning disk became a performance bottleneck after switching Mac Mini from server duty to desktop duty. I purchased the dual drive kit for the flexibility of adding a second SSD down the road. But for now, the single drive setup suits my needs perfectly.
Meine Reparatur
I'm writing this review on the Mac Mi . . .
Mein Problem
2011 Mac mini was starting to show it's age and needed an upgrade.
Meine Reparatur
Repair went perfectly! This kit gave me the tools for the job and the guide was a perfect companion! I was able to add an SSD and now my Mac Mini is running better than ever!
The install went so quick I forgot to take pictures!
Mein Rat
Pay at . . .
Mein Problem
Just wanted more storage, and replaced the system drive with a SSD.
Meine Reparatur
It went well.
Mein Rat
Be mindful of the cable connections to the PCB, and the top drive mounts built into the chassis are hard to locate during reinstall.
Mein Problem
Upgrade to ssd storage and memory
Meine Reparatur
Easy with the instructions. Lifted infrared cable port off card before receiving the package.... wouldn't have happened if I had the tool kit that comes with.
Mein Rat
Spudger
Mein Problem
No problems but, we replaced our old WD externel drive that started to get noisy with a new Synology TS-251 2-bay NAS external unit and a Seagate 4TB IronWolf NAS SATA 6Gb/s NCQ 64MB Cache 3.5-Inch Internal Hard Drive and thus wanted to have the old Mac Mini updated as well and installed a new Samsu . . .
Mehr anzeigen
