MacBook 12" Retina (Early 2016-2017) Battery
  • MacBook 12" Retina (Early 2016-2017) Battery / New / Fix Kit
  • MacBook 12" Retina (Early 2016-2017) Battery / New / Part Only
134,99 $
134,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook 12" Retina (Early 2016-2017) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 5210 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Battery adhesive is preinstalled to improve the quality of your repair.
Battery degradation is an inevitable part of your MacBook's lifespan, extend it with this new replacement battery compatible with MacBook 12" Retina (Early 2016-2017). Factory-installed MacBook 12" Retina (Early 2016-2017) batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kit Inhalt
Kit Inhalt
Kompatibilität
Kompatibilität
  • MacBook 12" Retina A1534 Early 2016 to 2017
Eigenschaften
Eigenschaften
Model #:
A1705
Watt Hours:
41.4 Wh
Voltage:
7.56
Milliamp Hours:
5474 mAh
Manufacturer:
Aftermarket
Kompatibilität
Retina MacBook 2016
A1534 (EMC 2991) 1.1 GHz
A1534 (EMC 2991) 1.2 GHz
A1534 (EMC 2991) 1.3 GHz
Retina MacBook 2017
A1534 (EMC 3099) 1.2 GHz
A1534 (EMC 3099) 1.3 GHz
A1534 (EMC 3099) 1.4 GHz
Kundenbewertungen
