MacBook 13" Santa Rosa Case Components
Grab a toolkit for your MacBook 13" Santa Rosa model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Ersatzteile für MacBook 13" Santa Rosa:
MacBook Front Display Bezel
Front Display Bezel
MacBook Memory Cover
Replace a bent or missing L-shaped metal cover for the RAM compartment in a MacBook laptop.
MacBook Santa Rosa/Penryn Upper Case with Keyboard
Replace an upper case, keyboard, trackpad, trackpad cable, and power button compatible with the MacBook model laptop. Part #922-9550, 922-8264, 922-8265, 661-5075, 661-50...
MacBook Santa Rosa/Penryn Lower Case
Replace a scratched-up lower case
MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
LCD mount including airport antenna cables.
MacBook Santa Rosa/Penryn Left Dust Guard
Left Dust Guard
MacBook Santa Rosa/Penryn Right Dust Guard
Right Dust Guard
MacBook Rear Display Bezel
Replace a damaged bezel without the cost of a new LCD
MacBook Clutch Cover
Replace a damaged or missing clutch cover for a MacBook laptop.
MacBook Optical Drive Bezel
Replaces warped or broken optical drive bezel
Geräteinformation
Santa Rosa architecture in this revision features faster bus speeds and a graphics processor upgrade! A comprehensive change to a new type of logic board connector makes this version largely incompatible with prior MacBook versions.
The MacBook 13" Santa Rosa can be upgraded to a total of 6 GB of memory using a 4 GB RAM chip and a 2 GB RAM chip. Don't let all that RAM go to waste. The 500 GB 7200 RPM SATA hard drive will give you plenty of storage. The fastest optical drive for this model is the 8x SuperDrive and it will make burning CDs a breeze.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
