Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
MacBook Air 11" (Mid 2011-Early 2015) Replacement Battery
  • MacBook Air 11" (Mid 2011-Early 2015) Replacement Battery / Fix Kit
  • MacBook Air 11" (Mid 2011-Early 2015) Replacement Battery / Part Only
  • 360°
360
84,99 $
84,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Nintendo Switch Kits
Eine schnelle Lösung, um wieder ins Spiel zu kommen
Switch Kits kaufen
Switch Kits kaufen
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Air 11" (Mid 2011-Early 2015) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 4850 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop's lifespan, extend it with this new replacement battery compatible with Mid 2011 to Early 2015 model 11" MacBook Airs. Factory-installed MacBook Air batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kit Inhalt
Kit Inhalt
Kompatibilität
Kompatibilität
  • MacBook Air 11" A1370 Mid 2011
  • MacBook Air 11" A1465 Mid 2012 to Early 2015
Eigenschaften
Eigenschaften
Model #:
A1495
Watt Hours:
38.75 Wh
Voltage:
7.6 V
Milliamp Hours:
5100 mAh
Manufacturer:
Aftermarket
Kompatibilität
MacBook Air 11" Early 2014
A1465 (EMC 2631) 1.4 GHz
A1465 (EMC 2631) 1.7 GHz
MacBook Air 11" Early 2015
A1465 (EMC 2924) 1.6 GHz
A1465 (EMC 2924) 2.2 GHz
MacBook Air 11" Mid 2011
A1370 (EMC 2471) 1.6 GHz
A1370 (EMC 2471) 1.8 GHz
MacBook Air 11" Mid 2012
A1465 (EMC 2558) 1.7 GHz
A1465 (EMC 2558) 2.0 GHz
MacBook Air 11" Mid 2013
A1465 (EMC 2631) 1.3 GHz
2 weitere Geräte zeigen
Kundenbewertungen
