Ersatzteile Mac MacBook Air 13" Mid 2013 Hard Drive Brackets
Store
Du kennst dein Modell nicht? Mac identifizieren
MacBook Air 13" (Late 2010-2017) Replacement Battery / Fix Kit
An aftermarket replacement battery compatible with a MacBook Air 13" laptop.
Von 79,99 $
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 $
OWC Aura Pro X2 SSD
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs.
Von 149,99 $
MacBook Air 13" (Mid 2011-Early 2015) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard compatible with a model A1369 13" MacBook Air from mid 2011 or a model A1466 13" MacBook Air from mid 2012 ...
19,99 $
MacBook Air 13" (Mid 2013-2017) I/O Board
Replace a damaged or corroded I/O board for your Mid 2013 to 2017 MacBook Air 13" and fix problems with charging, audio, and data connections. This assembly includes the ...
79,99 $
MacBook Air 13" (Mid 2013-2017) Trackpad Cable
Replace a torn or damaged cable connecting the trackpad to the logic board in a Mid 2013 to 2017 13" MacBook Air.
14,99 $
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
9,99 $
Replace a scratched or malfunctioning trackpad compatible with a Mid 2013 to 2017 MacBook Air 13" laptop.
Von 49,99 $
MacBook Air 13" (Late 2010-2017) Lower Case Screw Set
Replace missing screws in the lower case of your laptop. This set is compatible with a Late 2010 to 2017 MacBook Air 13" laptop.
19,99 $
Angezeigte Artikel 1 - 10 von 33
Geräteinformation
Released on June 10, 2013, this 13" MacBook Air looks much the same as its predecessor externally, but internally Apple made several improvements. A more efficient 1.3 GHz Intel "Core i5" processor results in improved battery life and faster graphics. Other features include 802.11ac Wi-Fi and Bluetooth 4.0 connectivity, a "Thunderbolt" port, an SD card slot, and two USB 3.0 ports.
