Ersatzteile Mac MacBook Air 13" Hard Drives (SATA)
Store
Du kennst dein Modell nicht? Mac identifizieren
MacBook Air 13" (Late 2010-2017) Replacement Battery / Fix Kit
An aftermarket replacement battery compatible with a MacBook Air 13" laptop.
Von 79,99 $
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 $
OWC Aura Pro X2 SSD
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs.
Von 149,99 $
MacBook Air 13" (Mid 2011-Early 2015) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard compatible with a model A1369 13" MacBook Air from mid 2011 or a model A1466 13" MacBook Air from mid 2012 ...
19,99 $
Apple MagSafe 1 AC Adapter / 85 W / AC Adapter End / New
Replace a broken or damaged Apple MagSage 1 AC adapter with this part.
Von 39,99 $
MacBook Air 13" (Mid 2013-2017) I/O Board
Replace a damaged or corroded I/O board for your Mid 2013 to 2017 MacBook Air 13" and fix problems with charging, audio, and data connections. This assembly includes the ...
79,99 $
MacBook Air 13" (Mid 2013-2017) Trackpad Cable
Replace a torn or damaged cable connecting the trackpad to the logic board in a Mid 2013 to 2017 13" MacBook Air.
14,99 $
MacBook Air Plastic Feet
Replace the black plastic feet on the lower case of your laptop. These feet are compatible with most 11" or 13" MacBook Air laptops.
4,99 $
Replace a scratched or malfunctioning trackpad compatible with a Mid 2013 to 2017 MacBook Air 13" laptop.
Von 49,99 $
Angezeigte Artikel 1 - 10 von 132
Geräteinformation
When the MacBook Air was released, it was the thinnest notebook computer yet. A minimalist port design and multitouch trackpad are characteristic of the MacBook Air.
In October of 2010, Apple introduced a total redesign of the MacBook Air 13". The new Air features a flash memory module instead of a conventional hard drive, and the battery dominates most of the internal space. This lack of conventional hard drive allows the machine to be insanely thin.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your machine above for parts and more!
