MacBook Air 13" (Mid 2011) I/O Board
  • MacBook Air 13" (Mid 2011) I/O Board
Zustand: Gebraucht
52,99 $
52,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
Artikelbeschreibung
Beschreibung
Beschreibung
  • Replace a broken or damaged I/O board for your Mid 2011 MacBook Air 13" laptop with this part. This assembly includes the MagSafe power, USB, and audio port.
  • This is a used OEM part.
Kompatibilität
Reparatur-Geschichten
Nutzeravatar
Mein Problem
twas burnt out. The outside contacts of the power adapter were charred
Meine Reparatur
luckily I had the tools from a battery replacement. I installed it no problem, didn't' seem to work so I pulled it. Then I decided to try a new power supply so I reinstalled it and it's beautiful now. Gave my wife her own computer . . .
Nutzeravatar
Mein Problem
The MagSafe connection was burn and I couldn't charge my Mac. New MagSafe was needed in order to charge it.
Meine Reparatur
It was very easy, the guide is super clear and the pictures sharp and big. Took me less then 10 minutes to repair.
Mein Rat
Yes, the 2 screwdrivers does not open the cover of the Mac, only connections in . . .
Nutzeravatar
Mein Problem
Charger would act sporadically. Sometimes charging and sometimes not, sometimes depending on position of the cable. Laptop would heat up above the "esc" key (approximately where the I/O board is). Battery life was non-existent.
Meine Reparatur
So I replaced the I/O and battery and before that the top case. Real easy . . .
Nutzeravatar
Mein Problem
he said that it would not take a charge,no camera ,no sound.
Meine Reparatur
once i found i fix it, and found out that it was going to be the i/o board, it has to be the easiest repair i have ever attempted
Mein Rat
great site
Nutzeravatar
Mein Problem
I had damaged both my USB drives with a bad peripheral device and neither were working. When I tool my computer to the store, Apple gave me an estimate of $450 to replace the I/O board.
Meine Reparatur
The repair went great. I was done in 10 minutes.
Mein Rat
Be sure to order the proper tools with your parts. This made every . . .
Nutzeravatar
Mein Problem
The magsafe connector lights up but the mba doesnt recognize it is plugged.. I had to play with the connector a bit to make it recognized by the mba.
Meine Reparatur
First time to open up my mba. It was all dusty inside. Repair went smoothly. Ifixit's guide was awesome. The step by step guides are very detailed. I h . . .
Nutzeravatar
Mein Problem
Wife's Macbook Air A1369, despite being pretty new, stopped taking charge off the magsafe connector reliably, unless you pushed firmly on the connector and wiggled it like a fool for several minutes. After trying a couple different Magsafe power supplies, I decided it was the "charge controller," or . . .
Mehr anzeigen
