MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
  • MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
Zustand: Gebraucht
7,99 $
7,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
Erfolgreich repariert? Genial!
Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
Wir sind alle Genies
Artikelbeschreibung
Beschreibung
Beschreibung
LCD hanging on by a thread?
Lock it down with some LCD mounts! Includes LCD mounts and airport antenna cables.
This part works with model A1181 MacBooks with 2 antenna connectors. If your MacBook has 3 antenna connectors you need the Core 2 Duo hinge mounts.
Kompatibilität
MacBook Core 2 Duo
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz
2 GHz
Reparatur-Geschichten
Nutzeravatar
Mein Problem
WIFI antenna wire was broken where it passes through the hinge of the display.
Meine Reparatur
The online guide was helpful - take the time to go slow and follow each step.
Mein Rat
Set aside enough time to do the repair right - keep track of where the screws from each step go so you don't get them mixed up later.
Nutzeravatar
Mein Problem
My airport would only work if the computer did not move after startup. If moved the airport would turn off and could not be turned back on without restarting. After researching the problem I deduced that it was probable that the antenna wires had been pinched/worn from the screen opening and closing . . .
