Ersatzteile Mac MacBook Pro 13" Function Keys Late 2016 Hard Drives (SATA)
Store
Du kennst dein Modell nicht? Mac identifizieren
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 $
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery / Fix Kit
Replacement battery compatible with MacBook Pro 13" Retina (Function Keys, Late 2016/2017).
Von 139,99 $
MacBook Pro 13" Retina (Late 2016-2019) Display Assembly / A-Stock / Silver
The display assembly includes the Retina LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, display daughter board, and cable spring mechanism. Compatib...
599,99 $
MacBook Pro Retina (2016-2019) Display Backlight Cables
Replace the two flex cables connecting the display backlight to the display daughter baord.
9,99 $
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Fan
Replace a malfunctioning or noisy fan.
Von 29,99 $
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Display Cable
Replace the short flex cable that connects the display daughter board to the logic board.
24,99 $
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Lower Case / Silver / New
Replace a scratched or dented lower case.
Von 29,99 $
MacBook Pro 13" Retina (Late 2016-2019) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 to 2019 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
Von 49,99 $
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Lower Case Screw Set / Silver
Replace the external screws securing the lower case.
19,99 $
Angezeigte Artikel 1 - 10 von 36
Geräteinformation
Released in October 2016 with the Apple model number A1708 / EMC 2978, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). This model packs an Intel Core i5 and two Thunderbolt 3 ports.
The most common repairs with the 13" Late 2016 model MacBook Pro with Retina Display and Function Keys laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Function Keys Late 2016 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Function Keys Late 2016 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Function Keys Late 2016 earned a 2 out of 10 in iFixit's repairability assessment. Watch the Teardown Review for more:
