Ersatzteile Mac MacBook Pro 13" Retina Late 2013 USB Boards
Store
Du kennst dein Modell nicht? Mac identifizieren
MacBook Pro Retina (A1425, A1502, and A1398) Plastic Feet / Part Only
Replace missing or damaged black plastic feet on your laptop's lower case.
Von 4,99 $
MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery
Replacement 6330 mAh battery compatible with a MacBook Pro 13" Retina (Late 2013/Mid 2014) laptop.
Von 89,99 $
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 $
OWC Aura Pro X2 SSD
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs.
Von 149,99 $
MacBook Pro Retina (2012-2015) Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case.
Von 19,99 $
MacBook Pro Retina (2012-2015) Display LVDS Cable
Replace a damaged connector or torn LVDS display cable.
19,99 $
MacBook Pro 13" Retina (Late 2013-Early 2015) Left Speaker
Replace a broken or damaged left speaker for your Late 2013 to Early 2015 MacBook Pro 13" Retina laptop with this part and fix sound issues.
27,99 $
MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board
Replace a broken or damaged MagSafe 2 DC-in board for your Late 2013 to Early 2015 MacBook Pro 13" Retina laptop with this part. This part connects wall adapter power to ...
Von 20,99 $
MacBook Pro 13" Retina (Late 2013-Early 2015) Right Speaker
Replace a broken or damaged right speaker for your Late 2013 to Early 2015 MacBook Pro 13" Retina laptop with this part and fix sound issues.
29,99 $
Angezeigte Artikel 1 - 10 von 36
Geräteinformation
On October 22, 2013 Apple introduced a new 13" MacBook Pro with Retina Display. Externally, this "Late 2013" model looks very much like the "Early 2013" model, but the new case is slightly thinner and the weight has been trimmed from 3.57 pounds to 3.46 pounds. The 13.3" widescreen 2560x1600 (227 ppi) display is unchanged while some external ports and Wi-Fi capabilities have been improved. The Late 2013 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the Early 2013 model the Late 2013 does not have Ethernet or Firewire ports, although adapters are available.
The most common repairs with the 13" Late 2013 model MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina Late 2013 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display Late 2013 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display Late 2013 earned a 1 out of 10 in iFixit's repairability assessment. Watch the Teardown Review for more:
