Ersatzteile Mac MacBook Pro 13" Retina Late 2012 USB Boards
Store
Du kennst dein Modell nicht? Mac identifizieren
MacBook Pro Retina (A1425, A1502, and A1398) Plastic Feet / Part Only
Replace missing or damaged black plastic feet on your laptop's lower case.
Von 4,99 $
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 $
MacBook Pro Retina (2012-2015) Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case.
Von 19,99 $
MacBook Pro 13" Retina (Late 2012-Early 2013) Battery / New / Fix Kit
Replace a 6600 mAh battery compatible with a MacBook Pro 13" Retina (Late 2012/Early 2013) laptop.
Von 89,99 $
OWC Aura Pro 6G SSD
OWC Aura Pro 6G SSD
Replace or upgrade the SSD in a 13" or 15" MacBook Pro with Retina Display from 2012 or Early 2013.
Von 119,99 $
MacBook Pro Retina (2012-2015) Display LVDS Cable
Replace a damaged connector or torn LVDS display cable.
19,99 $
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
9,99 $
Apple MagSafe 2 AC Adapter
Replace a broken or damaged Apple MagSage 2 AC adapter with this part.
Von 49,99 $
MacBook Pro Retina (A1425, A1502, and A1398) Lower Case Screw and Foot Kit
Replace a missing or scuffed plastic foot or a missing screw securing the lower case of your laptop.
29,99 $
Angezeigte Artikel 1 - 10 von 36
Geräteinformation
On October 23, 2012 Apple announced the new 13" MacBook Pro with Retina display. Similar to its larger cousin, the 15" MacBook Pro with Retina display introduced earlier in 2012, this new 13" MacBook Pro features a high resolution LED-backlit display. An integrated Intel HD Graphics 4000 graphics processor takes full advantage of the 2560-by-1600 resolution at 227 pixels per inch. The MBP Retina 13" has two USB 3 ports, an SDXC card slot, an HDMI port, and two ThunderBolt ports. It does not have Ethernet or Firewire ports, although adapters are available. The MagSafe Port has also been replaced with the MagSafe 2 port allowing for a thinner case design.
The most common repairs with the 13" Late 2012 model MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina Late 2012 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display Late 2012 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display Late 2012 earned a 2 out of 10 in iFixit's repairability assessment.
