Ersatzteile Mac MacBook Pro 13" Retina Case Components
Store
Du kennst dein Modell nicht? Mac identifizieren
MacBook Pro 13" Retina (Early 2015) Lower Case
Replace a broken or damaged lower case for your Early 2015 MacBook Pro 13" Retina laptop with this part.
Von 89,99 $
MacBook Pro 13" Retina (Early 2015) Upper Case Assembly
The Upper Case Assembly includes the backlit keyboard.
Von 199,99 $
MacBook Pro 13" Retina (Late 2016-2017) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 or 2017 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
Von 69,99 $
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Upper Case / New / Dark Gray
Replace a dented or scratched upper case or malfunctioning keyboard in your laptop.
199,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Upper Case / New / Dark Gray
Replace a dented or scratched upper case, malfunctioning keyboard, or malfunctioning Touch Bar in a 2016 or 2017 model 13" MacBook Pro with Retina Display and Touch Bar.
209,99 $
MacBook Pro 13" Retina (Late 2013-Mid 2014) Lower Case
Replace a broken or damaged lower case for your Late 2013 or Mid 2014 MacBook Pro 13" Retina laptop with this part.
Von 49,99 $
MacBook Pro 13" Retina (Late 2013-Mid 2014) Upper Case Assembly / A-Stock / With Trackpad and Battery
The Upper Case Assembly includes the backlit keyboard and may include the battery and trackpad.
Von 149,99 $
MacBook Pro 13" Retina (Late 2016-2017) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 or 2017 model 13" MacBook Pro with Retina Display.
5,99 $
MacBook Pro 13" Retina (Late 2016-2017) Touch Bar Display Cable Brackets
Replace a bent or missing metal bracket securing the touch bar interconnect cable connectors to the Touch Bar or the logic board in a 2016 or 2017 model 13" MacBook Pro w...
3,99 $
Angezeigte Artikel 1 - 10 von 28
Geräteinformation
Late in 2012 Apple released the MacBook Pro 13" with a new Retina display having 2560-by-1600 resolution. The Retina Display models that followed the 2012 model vary by specifications and features.
The most common repairs with the 13" MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly. Choose a model for more specific information.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display repair guides for step-by-step instructions on how to make the fix.
