MacBook Pro 13" Touch Bar 2019 Case Components
Grab a toolkit for your MacBook Pro 13" Touch Bar 2019 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Ersatzteile für MacBook Pro 13" Touch Bar 2019:
MacBook Pro 13" Retina (A1706, A1708, A1989, A2251) Trackpad
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 to 2020 model A1706, A1708, A1989, or A2251 MacBook Pro 13" with Retina Display.
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
MacBook Pro 13" Retina (Late 2016-2020) Trackpad Cable Bracket
Replace a bent or missing metal bracket that secures the trackpad cable connector to the logic board compatible with 2016 to 2020 model 13 inch MacBook Pro laptops.
MacBook Pro 13" Retina (Late 2016-2020) Display Cable Brackets
Replace the brackets that secure the display cable connector to the display daughter board and clamp the middle of the cable to the upper case assembly in a 2016 to 2020 ...
MacBook Pro 13" Retina (Mid 2018-2019) Upper Case
Replace an upper case or keyboard compatible with the Mid 2018 to 2019 MacBook Pro 13" Retina laptop.
MacBook Pro 13" Retina (Late 2016-2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2020 model 13" MacBook Pro with Retina Display.
MacBook Pro 13" Retina (Late 2016-2019) Touch Bar Display Cable Brackets
Replace a bent or missing metal bracket securing the touch bar interconnect cable connectors to the Touch Bar or the logic board in a 2016 to 2019 model 13" MacBook Pro w...
MacBook Pro 13" Retina (2018-2020) USB-C Cable Bracket
Replace a bent or missing bracket that secures the USB-C cable to the logic board in a 2018 to 2020 model 13" MacBook Pro with Retina Display.
MacBook Pro 13" Retina (Touch Bar, Late 2016-2020) Hinge Covers
Replace the plastic covers for the display hinges.
MacBook Pro 13" Retina (2019) 2.4 GHz Logic Board with Paired Touch ID Sensor
Replace a 2.4 GHz Core i5 logic board (motherboard) compatible with the MacBook Pro 13" Retina (2019). Includes 8 GB or 16 GB of RAM, paired Touch ID sensor, and SSD. Fix...
Geräteinformation
Introduced in May 2019, this 13" Macbook Pro features Coffee Lake processors up to 2.8 GHz Core i7 with Turbo Boost up to 4.7 GHz. Model A1989.
The most common repairs with the 13" 2019 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2019 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2019 repair guides for step-by-step instructions on how to make the fix.
