Ersatzteile Mac MacBook Pro 13" Touch Bar Late 2016 Case Components
Store
Du kennst dein Modell nicht? Mac identifizieren
MacBook Pro 13" Retina (Late 2016-2017) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 or 2017 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
Von 69,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Upper Case / New / Dark Gray
Replace a dented or scratched upper case, malfunctioning keyboard, or malfunctioning Touch Bar in a 2016 or 2017 model 13" MacBook Pro with Retina Display and Touch Bar.
209,99 $
MacBook Pro 13" Retina (Late 2016-2017) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 or 2017 model 13" MacBook Pro with Retina Display.
5,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Headphone Jack Bracket
Replace a bent or missing metal bracket that secures the headphone jack cable connector to the logic board in a 2016 or 2017 model 13" MacBook Pro with Retina Display and...
3,99 $
MacBook Pro 13" Retina (Late 2016-2017) Display Gasket
Replace the elastic plastic gasket that fits around the outside edge of the display assembly for a Late 2016 or 2017 model 13" MacBook Pro with Retina Display.
9,99 $
MacBook Pro 13" Retina (Late 2016-2017) Display Hinge Spring
Replace a damaged spring tension hinge bracket compatible with a Late 2016 or 2017 model 13" MacBook Pro with Retina display.
9,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Lower Case / Silver / New
Replace a scratched or dented lower case compatible with a 2016 or 2017 model 13" MacBook Pro with Retina Display and Touch Bar.
49,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Upper Case Assembly / A-Stock / Dark Gray
Replace a dented or scratched upper case, malfunctioning keyboard, malfunctioning Touch Bar, or dead battery in a 2016 or 2017 model 13" MacBook Pro with Retina Display a...
499,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Display Cable Brackets
Replace the brackets that secure the display cable connector to the display daughter board and clamp the middle of the cable to the upper case assembly in a 2016 or 2017 ...
4,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Trackpad Cable Bracket
Replace a bent or missing metal bracket that secures the trackpad cable connector to the logic board in a 2016 or 2017 model 13" MacBook Pro with Retina Display and Touch...
3,99 $
Angezeigte Artikel 1 - 10 von 12
Geräteinformation
Released in November 2016 with the Apple model number A1706 / EMC 3071, this 13" Macbook Pro introduces the OLED Touch Bar, and features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
The most common repairs with the 13" Late 2016 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar Late 2016 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar Late 2016 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Touch Bar Late 2016 earned a 1 out of 10 in iFixit's repairability assessment. Watch the Teardown Review for more:
