Ersatzteile Mac MacBook Pro 13" Touch Bar Mid 2017 Hard Drives (SATA)
Store
Du kennst dein Modell nicht? Mac identifizieren
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case Screw Set / Silver
Replace the external screws securing the lower case.
19,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Battery / Fix Kit
Replace a dead or malfunctioning battery compatible with a MacBook Pro 13" Retina (Touch Bar, Late 2016/2017).
Von 119,99 $
MacBook Pro Retina (2016-2019) Display Backlight Cables
Replace the two flex cables connecting the display backlight to the display daughter baord.
9,99 $
MacBook Pro 13" Retina (Late 2016-2019) Display Assembly / A-Stock / Silver
The display assembly includes the Retina LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, display daughter board, and cable spring mechanism. Compatib...
599,99 $
MacBook Pro 13"/15" Retina (Touch Bar, Late 2016-2017) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard.
149,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case / Silver / New
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
Von 34,99 $
MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board / New
Replace one of the thunderbolt connector boards from the left or right side of your laptop.
Von 29,99 $
MacBook Pro Retina (Late 2016-Mid 2017) Plastic Feet
Replace missing or damaged black plastic feet on the lower case of your laptop.
4,99 $
Angezeigte Artikel 1 - 10 von 42
Geräteinformation
Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz. Model A1706.
The most common repairs with the 13" 2017 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2017 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2017 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Touch Bar 2017 earned a 1 out of 10 in iFixit's repairability assessment.
