Ersatzteile Mac MacBook Pro 13" Touch Bar Mid 2017 SSD Enclosures
Store
Du kennst dein Modell nicht? Mac identifizieren
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Battery / New / Fix Kit
Replace a dead or malfunctioning battery compatible with a MacBook Pro 13" Retina (Touch Bar, Late 2016/2017).
Von 119,99 $
MacBook Pro 13"/15" Retina (Touch Bar, Late 2016-2017) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard.
149,99 $
MacBook Pro 13" Retina (Late 2016-2017) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 or 2017 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
Von 69,99 $
MacBook Pro Retina (Late 2016-Mid 2017) Plastic Feet
Replace missing or damaged black plastic feet on the lower case of your laptop.
4,99 $
OWC Thunderbolt 3 10G Ethernet Adapter
Connect to high-performance wired networks and storage via Thunderbolt 3.
149,99 $
MacBook Pro 13" Retina (Touch Bar, 2017) 3.1 GHz Logic Board
Replace a damaged or malfunctioning 3.1 GHz Core i5 Motherboard. The Touch ID sensor is paired to the logic board and is included.
Von 499,99 $
MacBook Pro 13" Retina (Late 2016-2017) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 or 2017 model 13" MacBook Pro with Retina Display.
5,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Right Large Speaker
Replace a damaged or malfunctioning right side low frequency speaker compatible with a Late 2016 or 2017 MacBook Pro 13" with Touch Bar.
Von 29,99 $
Angezeigte Artikel 1 - 10 von 41
Geräteinformation
Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz. Model A1706.
The most common repairs with the 13" 2017 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2017 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2017 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Touch Bar 2017 earned a 1 out of 10 in iFixit's repairability assessment.
