Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina MacBook Pro 13" Touch Bar Mid 2017 SSD Enclosures
US Store
Grab a toolkit for your MacBook Pro 13" Touch Bar Mid 2017 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Du kennst dein Modell nicht? Mac identifizieren
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
9,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Battery / Fix Kit
Replace a 4310 mAh battery compatible with MacBook Pro 13" Retina (Touch Bar, Late 2016/2017). 49.2 Watt Hours (Wh), 11.41 Volts (V).
Von 129,99 $
MacBook Pro 13" Retina (Late 2016-2017) Display Assembly / Premium / Silver
Replace a display compatible with the Function Keys or Touch Bar late 2016 to mid 2017 model A1706 or A1708 MacBook Pro 13" Retina laptop. Includes the 2560 x 1600 13.3" ...
499,99 $
MacBook Pro 13"/15" Retina (Touch Bar, Late 2016-2017) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard.
149,99 $
MacBook Pro 13" Retina (Late 2016-2019) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 to 2019 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
69,99 $
MacBook Pro Retina (Late 2016-Mid 2017) Plastic Feet
Replace missing or damaged black plastic feet on the lower case of your laptop.
4,99 $
MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board / New
Replace one of the thunderbolt connector boards from the left or right side of your laptop.
34,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Trackpad Cable / New
Replace the flex cable that connects the trackpad to the logic board compatible with the Late 2016 to 2019 Touch Bar Retina MacBook Pro 13 inch laptop. Part #821-01063-01...
Von 24,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Left Small Speaker
Replace the high frequency tweeter speaker compatible with the Late 2016 to 2019 MacBook Pro 13" Retina Touch Bar laptop. Fix issues with sound output.
Von 19,99 $
Angezeigte Artikel 1 - 10 von 45
Geräteinformation
Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz. Model A1706.
The most common repairs with the 13" 2017 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2017 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2017 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Touch Bar 2017 earned a 1 out of 10 in iFixit's repairability assessment.
