Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 13" Retina (Early 2015) Battery
  • MacBook Pro 13" Retina (Early 2015) Battery / New / Fix Kit
  • MacBook Pro 13" Retina (Early 2015) Battery / New / Part Only
  • 360°
360
109,99 $
109,99 $
Das Essential Toolkit
Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
Jetzt kaufen
Jetzt kaufen
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 13" Retina (Early 2015) replacement battery fix kit includes all the parts, tools, and adhesive you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 6230 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your MacBook Pro's lifespan, extend it with this new replacement battery compatible with MacBook Pro 13" Retina (Early 2015). Factory-installed MacBook Pro 13" Retina (Early 2015) batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kit Inhalt
Kit Inhalt
Kompatibilität
Kompatibilität
  • MacBook Pro 13" Retina A1502 Early 2015
Eigenschaften
Eigenschaften
Model #:
A1582
Watt Hours:
74.9 Wh
Voltage:
11.36 V
Milliamp Hours:
6560 mAh
Manufacturer:
Aftermarket
Kompatibilität
MacBook Pro 13" Retina Display Early 2015
A1502 (EMC 2835) 2.7 GHz
A1502 (EMC 2835) 2.9 GHz
A1502 (EMC 2835) 3.1 GHz
Kundenbewertungen
