Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 13" Retina (Mid 2018-Early 2019) Battery
  • MacBook Pro 13" Retina (Mid 2018-Early 2019) Battery / Part Only
139,99 $
139,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 13" Retina (Mid 2018-Early 2019) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 5086 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
  • Battery adhesive is preinstalled to improve the quality of your repair.
Battery degradation is an inevitable part of your MacBook Pro's lifespan, extend it with this new replacement battery compatible with MacBook Pro 13" Retina (Mid 2018-Early 2019). Factory-installed batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Die Einheit enthält
Die Einheit enthält
  • New Replacement Battery compatible with a mid 2018 or early 2019 model MacBook Pro 13" Retina
  • Installation Adhesive
Kompatibilität
Kompatibilität
  • MacBook Pro 13" Retina A1989 Mid 2018 to 2019
Eigenschaften
Eigenschaften
Model #:
A1964
Watt Hours:
58 Wh
Voltage:
11.41 V
Milliamp Hours:
5086 mAh
Kompatibilität
MacBook Pro 13" Touch Bar 2018
A1989 (EMC 3214) 2.3 GHz
A1989 (EMC 3214) 2.7 GHz
MacBook Pro 13" Touch Bar 2019
A1989 (EMC 3358) 2.4 GHz
A1989 (EMC 3358) 2.8 Ghz
Kundenbewertungen
