Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 13" Retina (Mid 2019) Battery
  • MacBook Pro 13" Retina (Mid 2019) Battery / Fix Kit
  • MacBook Pro 13" Retina (Mid 2019) Battery / Part Only
149,99 $
149,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 13" Retina (Two Thunderbolt Ports, Mid 2019) replacement battery fix kit includes all the parts, tools, and adhesive you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 5100 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Battery adhesive is preinstalled to improve the quality of your repair.
Battery degradation is an inevitable part of your MacBook Pro's lifespan, extend it with this new replacement battery compatible with MacBook Pro 13" Retina (Two Thunderbolt Ports, Mid 2019). Factory-installed batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Die Einheit enthält
Die Einheit enthält
  • New Replacement Battery compatible with a mid 2019 Two Thunderbolt Ports model MacBook Pro 13" Retina
  • Installation Adhesive
Kit Inhalt
Kit Inhalt
Kompatibilität
Kompatibilität
  • MacBook Pro 13" Retina A2159
  • Two Thunderbolt Ports Mid 2019
Eigenschaften
Eigenschaften
Model #:
A2171
Watt Hours:
58.2 Wh
Voltage:
11.41 V
Kompatibilität
MacBook Pro 13" Two Thunderbolt Ports 2019
A2159 (EMC 3301) 1.4 GHz
A2159 (EMC 3301) 1.7 GHz
