Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Display Assembly
  • MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Display Assembly
249,99 $
249,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
This Mid 2009 to Mid 2010 MacBook Pro 13" Unibody replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
An aging or battered laptop display may suffer a flickering image, dead pixels, or a dim backlight. Surface scratches can further degrade the image and a dented or warped case may pinch the display causing bright spots. Eliminate all these flaws with a replacement LCD display assembly. Our displays are individually tested and guaranteed to function perfectly.
Die Einheit enthält
Die Einheit enthält
  • 1280 x 800 13.3" LCD screen
  • Display cover
  • Bezel
  • iSight camera
  • Clutch hinges
  • Display inverter
  • Wi-Fi antenna
  • Display data cables
Kompatibilität
Kompatibilität
  • MacBook Pro 13" Unibody A1278 Mid 2009 and Mid 2010
Eigenschaften
Eigenschaften
Part #:
661-5232, 661-5558
Model #:
A1278
Resolution:
1280x800
Wi-Fi Protocol:
802.11n
Diagonal Size:
13.3"
Kompatibilität
MacBook Pro 13" Unibody Mid 2009
A1278 (EMC 2326) 2.26 GHz
A1278 (EMC 2326) 2.53 GHz
MacBook Pro 13" Unibody Mid 2010
A1278 (EMC 2351) 2.4 GHz
A1278 (EMC 2351) 2.66 GHz
Kundenbewertungen
