MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery
  • MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery / Fix Kit
  • MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery / Part Only
  • 360°
360
89,99 $
89,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 13" Unibody (Mid 2009-Mid 2012) replacement battery fix kit includes all the parts and tools you need to bring your dead MacBook Pro back to life!
  • 100% factory tested.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • New battery guaranteed at capacity greater than 5510 mAh.
Battery degradation is an inevitable part of your laptop's lifespan, extend it with this new replacement battery compatible with MacBook Pro 13" Unibody (Mid 2009-Mid 2012). Factory-installed MacBook Pro batteries are only rated to last 1,000 cycles. If your MacBook Pro won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kit Inhalt
Kit Inhalt
Kompatibilität
Kompatibilität
  • MacBook Pro 13" Unibody A1278 Mid 2009 to Mid 2012
Eigenschaften
Eigenschaften
Part #:
661-5557
Model #:
A1322
Watt Hours:
63.5 Wh
Voltage:
10.95 V
Milliamp Hours:
5800 mAh
Manufacturer:
Aftermarket
Installationsvideo
Kompatibilität
MacBook Pro 13" Unibody Early 2011
A1278 (EMC 2419) 2.3 GHz
A1278 (EMC 2419) 2.7 GHz
MacBook Pro 13" Unibody Late 2011
A1278 (EMC 2555) 2.4 GHz
A1278 (EMC 2555) 2.8 GHz
MacBook Pro 13" Unibody Mid 2009
A1278 (EMC 2326) 2.26 GHz
A1278 (EMC 2326) 2.53 GHz
MacBook Pro 13" Unibody Mid 2010
A1278 (EMC 2351) 2.4 GHz
A1278 (EMC 2351) 2.66 GHz
MacBook Pro 13" Unibody Mid 2012
A1278 (EMC 2554) 2.5 GHz
A1278 (EMC 2554) 2.9 GHz
2 weitere Geräte zeigen
Kundenbewertungen
