MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Replacement Battery
  • MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Replacement Battery / Fix Kit
  • MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Replacement Battery / Part Only
  • 360°
360
$89.99
$89.99
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Frohes Fest, frohes Tüfteln
Pack's ein, pack's aus, pack's an: Erhalte 12 € Rabatt auf deinen Einkauf ab 50 € mit dem Code FIXMAS12
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 13" Unibody (Mid 2009 to Mid 2012) Replacement Battery Fix Kit is everything you need to bring your laptop back back to life. Our aftermarket replacement batteries lead the industry in quality and reliability—each is tested and guaranteed to have a capacity greater than 5510 mAh—so you know you're getting the best part money can buy. This fix kit comes with a brand new battery and all the tools you need to make the fix.
Kit Inhalt
Kit Inhalt
Hinweis
Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Achtung
Lithium-ion batteries pose a fire hazard if they swell due to age or defect. Learn more about safe handling and proper disposal of all batteries.
Kompatibilität
MacBook Pro 13" Unibody Early 2011
2.3 GHz
2.7 GHz
MacBook Pro 13" Unibody Late 2011
2.4 GHz
2.8 GHz
MacBook Pro 13" Unibody Mid 2009
2.26 GHz
2.53 GHz
MacBook Pro 13" Unibody Mid 2010
2.4 GHz
2.66 GHz
MacBook Pro 13" Unibody Mid 2012
2.5 GHz
2.9 GHz
2 weitere Geräte zeigen
Reparatur-Geschichten
James May's Story Photo #1426220
Mein Problem
Battery life was getting so miserable, I couldn't depend on the old 'Pro anymore. I was seriously thinking it might be time to buy a new one, but I decided to try a new battery first.
Meine Reparatur
The iFixit kit came with everything I needed, and swapping the battery took only a few minutes. It was wonderfully re . . .
borist72's Story Photo #1426210
Mein Problem
Due to an upcoming trip, I finally decided to upgrade the original battery in my mid-2010 MacBook Pro. I contemplated purchasing the replacement on Amazon, eBay, or directly from Apple, but decided to go with iFixit after using their other products for multiple Mac repairs over the past 10 years. . . .
Scott Stuck's Story Photo #1367620
Mein Problem
As you can see from the photo, my old battery decided to hit puberty and started growing. To my surprise, the existing home we provided for that battery was too small. As a result, it decided to grow through the trackpad as quickly as possible.
Meine Reparatur
This was a super easy repair, albeit slightly scary be . . .
Mein Problem
dead battery
Meine Reparatur
nicely
Mein Rat
no
Mein Problem
Original battery from 2010 was dead - not handy for a laptop :)
Meine Reparatur
Flawless
Mein Rat
Great tools to go with it - gets the job done well!
Mein Problem
Battery life zero
Meine Reparatur
The driver bits did not fit screw heads well, if not careful could strip screw heads. Don’t be afraid to use excessive pressure
Mein Rat
Machine driver bits that fit screw heads better ie. find a better quality supplier maybe Germany
Mein Problem
battery said it needed to be replaced and was not holding as charge for very long
Meine Reparatur
Perfect. Using the provided tool I complete the repair in about 10 minutes with any problems.
Mein Rat
I've been using ifixit repair guides for years and they are simple the best. Nice step by step instructions.
Mein Problem
I still had the factory battery in my MacBook Pro. I bought it in 2009 so the battery was definitely at end of life. It would only stay charged for a half hour if it was off the charger.
Meine Reparatur
Great! Super easy. I did watch a Youtube video to make sure I was doing it correctly, but most could do the switch . . .
Mein Problem
wanted more battery life
Meine Reparatur
Great - this is easy.
Mein Rat
The instructions a bunch of steps for removing the faceplate entirely. The video skips that. I started removing the faceplate then realized I didn't need to -- so go with the video version. Much faster!
Works like a charm
Mein Problem
old battery
Meine Reparatur
great
Mein Rat
nope
Mehr anzeigen
