Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
  • MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
  • 360°
360
209,99 $
209,99 $
Das Essential Toolkit
Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
Jetzt kaufen
Jetzt kaufen
Artikelbeschreibung
Beschreibung
Beschreibung
Replace the 2.4 GHz logic board in your MacBook Pro 13" Unibody (Mid 2010) laptop and fix processing issues.
  • Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot.
A corroded, malfunctioning, or water-damaged logic board can cause unexpected shutdowns or reboots. Restore the functionality of your device with this replacement part.
Kompatibilität
Kompatibilität
  • MacBook Pro 13" Unibody A1278 Mid 2010
Eigenschaften
Eigenschaften
Part #:
661-5559
Model #:
A1278
Speed:
2.4 GHz
GPU:
NVIDIA GeForce 320M
Kompatibilität
MacBook Pro 13" Unibody Mid 2010
A1278 (EMC 2351) 2.4 GHz
A1278 (EMC 2351) 2.66 GHz
Reparatur-Geschichten
Nutzeravatar
Mein Problem
My MacBook Pro was suffering from the same Graphics problem as many others have experienced.
Meine Reparatur
I followed the instructions to take out the faulty Logic Board. Then I installed the replacement from iFixIt, with a little bit of thermal paste. Got it all screwed back together and was done in 25 Minutes. . . .
Nutzeravatar
Mein Problem
The logic board failed due to my daughter spilling milk on it. I tried to clean the board but the lactic acid managed to eat away some of the thin traces.
Meine Reparatur
I ordered a replacement from iFixIt, removed the old board and installed the new one. The system booted and everything worked as expected. So f . . .
Nutzeravatar
Mein Problem
My computer’s logic board stopped working, needed to be replaced.
Meine Reparatur
The repair was actually pretty easy and I felt proud of myself for the repair... and thankful for iFix :)
Mein Rat
Always be curious (but cautious)! There’s so many things you can do on your own and save money if you take the time to researc . . .
Nutzeravatar
Mein Problem
Broken RAM sloth, so the MacBook was working a bit slow.
Meine Reparatur
It went very well. The guide I used was very helpful and made the repair very easy! :)
Mein Rat
If you just follow the guide everything goes smoothly! :)
Nutzeravatar
Mein Problem
A few weeks ago my Macbook Pro started malfunctioning and gave me a blank white screen with a flashing folder and a question mark. I was unsure what this was and after some online research I figured it may be my hard drive. I installed a new hard drive but my Mac wouldn’t see it after going into r . . .
Nutzeravatar
Mein Problem
One drop or water got to the logic board
Meine Reparatur
simple replacement
Mein Rat
keep Mac away from ANY source of moisture
Mehr anzeigen
