MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
  • MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable / With Bracket / New
  • MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable / With Bracket / Used
  • MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable / Without Bracket / New
  • 360°
360
44,99 $
44,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Artikelbeschreibung
Beschreibung
Beschreibung
Replace a damaged hard drive cable in your Mid 2012 MacBook Pro 13" Unibody laptop computer with this part to fix the connection of an unrecognized drive.
Hinweis
Some options do not include the hard drive bracket, so be sure to select the appropriate product for your needs!
Kompatibilität
Reparatur-Geschichten
Tamer's Story Photo #1352444
Mein Problem
Old battery was making phone shut down at 20%
Meine Reparatur
I followed well made instructions exactly and the repair went better than I expected. I replaced old batteries on two iPhones so I bought one repair kit and then just one more battery. I didn't realize that the sticky tape was considered a seperate par . . .
Dan Oliver's Story Photo #1417246
Mein Problem
My MacBook Pro became really hard to charge. The MagSafe charger had to be put on just right, and it was getting harder and harder to charge. We have two chargers and both had the issue, so I felt sure the problem was on the computer side.
Meine Reparatur
Thanks to the great iFixit instructions and the spudger (grea . . .
Mein Problem
Almost no sound is heard.
Meine Reparatur
It was all easy and interesting to fix the phone itself with a Fix Kit.
Mein Rat
Be careful with small screws.
Mein Problem
Hero 4 was freezing despite all the suggested fixes on line, I decided to replace the image sensor
Meine Reparatur
I had no problem following the Fixit Instructions and replacing the image sensor. My Hero 4 now works again
Mein Rat
The most difficult part was removing the front panel - particularly the small tab just above t . . .
Mein Problem
The connection to the power cord was faulty. The light on the power cord would often times go out unless I put it at exactly the right angle. It also alternated between amber and green when charging. Furthermore, one of the terminals on the laptop power connector showed burn marks.
Meine Reparatur
The repair went re . . .
Mein Problem
Battery percentage would greatly reduce, like 73% then 20 min later be at 30%. You would plug it up and then it would show 69%.
Meine Reparatur
Went well. Had trouble with the adhesive tab breaking off. Had to use spudger to pry battery up a little then I was able to use the tweezers to get the adhesive strip and wa . . .
Mein Problem
- Faster and bigger disk needed --> SSD 1TB
- Battery is out (quick discharging) --> new battery
- RAM more needed --> 8 GB
Meine Reparatur
Easily with tool and guidelines. Result - perfect!!
Mein Rat
Just used the iFixit guides. Very useful. Thanks!
Mein Problem
My original battery quit working -- not only would not hold a charge but would not even work when plugged in.
Meine Reparatur
The repair went great. Easy instructions.
Mein Rat
Consider buying the P-5 Pentalobe and T-5 Torx screwdrivers and the spudger from IFIXIT. I couldn't find Pentalobe drivers at my local Ace hardware. . . .
Mein Problem
Somehow my LCD screen had gotten broken. I wish I had some cool story, but I literally have no idea.
Meine Reparatur
I’ve never done anything like this, but I figured it was worth a $23 investment for a new LCD screen and two tools as opposed to spending several hundred dollars on a new GoPro. Worst case, I’d be . . .
Mein Problem
My 5S has been giving me battery problems for about 6-9 months and eventually I got tired of having to charge my phone almost every 2 hours. Sometimes my battery would drop suddenly (60 to 20% and other random disparities). My camera also stopped working around the same time due to "overheating" so . . .
Mehr anzeigen
