Ersatzteile Mac MacBook Pro 15" Retina Early 2013 USB Boards
Store
Du kennst dein Modell nicht? Mac identifizieren
MacBook Pro Retina (A1425, A1502, and A1398) Plastic Feet / Part Only
Replace missing or damaged black plastic feet on your laptop's lower case.
Von 4,99 $
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery / New / Fix Kit
This replacement 8680 mAh battery is compatible with a MacBook Pro 15" Retina (Mid 2012/Early 2013).
Von 79,99 $
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 $
MacBook Pro Retina (2012-2015) Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case.
Von 19,99 $
MacBook Pro 15" Retina (Mid 2012-Mid 2015) Right Speaker
Replace a broken or damaged right speaker for your Mid 2012 to Mid 2015 MacBook Pro 15" Retina laptop with this part and fix sound issues.
29,99 $
1 TB SSD Hybrid 2.5" Hard Drive / Part Only
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive Hybrid, 5400 RPM / 2.5" wide x 9.5mm tall / 1 TB Unformatted
Von 84,99 $
MacBook Pro 15" Retina (Mid 2012-Mid 2014) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard compatible with a model A1398 15" MacBook Pro with Retina display from Mid 2012 to mid 2014.
19,99 $
MacBook Pro 15" Retina (Mid 2012-Mid 2015) Left Speaker
Replace a broken or damaged left speaker for your Mid 2012 to Mid 2015 MacBook Pro 15" Retina laptop with this part and fix sound issues.
29,99 $
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
9,99 $
Angezeigte Artikel 1 - 10 von 42
Geräteinformation
On February 13, 2013 Apple introduced a new 15" MacBook Pro with Retina display offering faster processors than those available in the Late 2012 models. The Early 2013 machines share most of the features of the Late 2012 models: a 2880x1800 LED-backlit display, an NVIDIA GeForce GT 650M graphics processor, and the same external ports. The Early 2013 MBP Retina 15" has two USB 3.0 ports, an SDXC card slot, an HDMI port, and two ThunderBolt ports. It does not have Ethernet or Firewire ports, although adapters are available. The MagSafe Port has also been replaced with the MagSafe 2 port allowing for a thinner case design.
The most common repairs with the 15" MacBook Pro Retina Early 2013 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Early 2013 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Early 2013 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 15" Retina Display Early 2013 earned a 1 out of 10 in iFixit's repairability assessment.
