MacBook Pro 15" Retina Late 2013 Integrated Graphics Case Components
Grab a toolkit for your MacBook Pro 15" Retina Late 2013 Integrated Graphics model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Ersatzteile für MacBook Pro 15" Retina Late 2013 Integrated Graphics:
MacBook Pro 15" Retina (Late 2013-Mid 2015) Lower Case
Replace a scratched or dented lower case compatible with a Late 2013 to Mid 2015 MacBook Pro 15" Retina laptop.
MacBook Pro 15" Retina (Late 2013-Mid 2014) Upper Case Assembly
Replace an upper case assembly compatible with the MacBook Pro 15 inch Retina Late 2013 to Mid 2014 model A1398. Part #661-8311.
Geräteinformation
On October 22, 2013 Apple introduced a new 15" MacBook Pro with Retina display that is externally identical to the "Early 2013" model by dimensions, weight, and 2880x1800 display resolution. Internally, the Late 2013 Integrated Graphics (IG) model has a faster and more efficient processor architecture, and a single Iris Pro 5200 graphics processor. The Late 2013 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the Early 2013 model the Late 2013 does not have Ethernet or Firewire ports, although adapters are available.
The most common repairs with the 15" MacBook Pro Retina Late 2013 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Late 2013 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Late 2013 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 15" Retina Display Late 2013 earned a 1 out of 10 in iFixit's repairability assessment.
