Ersatzteile Mac MacBook Pro 15" Retina Late 2013 Logic Boards
Store
Du kennst dein Modell nicht? Mac identifizieren
MacBook Pro 15" Retina (Mid 2014, Dual Graphics) 2.5 GHz Logic Board
2.5 GHz Core i7 Motherboard with Dual Graphics / Ports: 2 Thunderbolt (Mini DisplayPort), USB 3.0
349,99 $
MacBook Pro 15" Retina (Mid 2014, Integrated Graphics) 2.2 GHz Logic Board / 16  GB
2.2 GHz Core i7 Motherboard with Integrated Graphics / Ports: 2 Thunderbolt (Mini Display Port), USB 3.0
379,99 $
MacBook Pro 15" Retina (Late 2013, Dual Graphics) 2.3 GHz Logic Board
2.3 GHz Core i7 Motherboard with Dual Graphics / Ports: 2 Thunderbolt (Mini DisplayPort), USB 3.0
349,99 $
no image
MacBook Pro 15" Retina (Mid 2014, Dual Graphics) 2.8 GHz Logic Board
2.8 GHz Core i7 Motherboard with Dual Graphics / Ports: 2 Thunderbolt (Mini DisplayPort), USB 3.0
499,99 $
no image
MacBook Pro 15" Retina (Late 2013, Integrated Graphics) 2.6 GHz Logic Board
2.6 GHz Core i7 Motherboard with Integrated Graphics / Ports: 2 Thunderbolt (Mini DisplayPort), USB 3.0
Von 599,99 $
MacBook Pro 15" Retina (Late 2013, Dual Graphics) 2.6 GHz Logic Board
2.6 GHz Core i7 Motherboard with Dual Graphics / Ports: 2 Thunderbolt (Mini DisplayPort), USB 3.0
899,99 $
MacBook Pro 15" Retina (Mid 2014, Integrated Graphics) 2.5 GHz Logic Board / 16  GB
2.5 GHz Core i7 Motherboard with Integrated Graphics / Ports: 2 Thunderbolt (Mini Display Port), USB 3.0
649,99 $
MacBook Pro 15" Retina (Mid 2014, Integrated Graphics) 2.8 GHz Logic Board / 16  GB
2.8 GHz Core i7 Motherboard with Integrated Graphics / Ports: 2 Thunderbolt (Mini Display Port), USB 3.0
699,99 $
MacBook Pro 15" Retina (Late 2013, Integrated Graphics) 2.0 GHz Logic Board
2.0 GHz Core i7 Motherboard with Integrated Graphics / Ports: 2 Thunderbolt (Mini Display Port), USB 3.0
Von 249,99 $
no image
MacBook Pro 15" Retina (Late 2013, Integrated Graphics) 2.3 GHz Logic Board
2.3 GHz Core i7 Motherboard with Integrated Graphics / Ports: 2 Thunderbolt (Mini DisplayPort), USB 3.0
Von 549,99 $
Angezeigte Artikel 1 - 10 von 10
Geräteinformation
On October 22, 2013 Apple introduced a new 15" MacBook Pro with Retina display that is externally identical to the "Early 2013" model by dimensions, weight, and 2880x1800 display resolution. Internally, the Late 2013 model has a faster and more efficient processor architecture, entry level models have a single integrated graphics (IG) processor, and higher-end models offer a dual graphics (DG) processor. The Late 2013 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the Early 2013 model the Late 2013 does not have Ethernet or Firewire ports, although adapters are available.
The most common repairs with the 15" MacBook Pro Retina Late 2013 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Late 2013 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Late 2013 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 15" Retina Display Late 2013 earned a 1 out of 10 in iFixit's repairability assessment.
