MacBook Pro 15" Retina Mid 2012 Logic Boards
Grab a toolkit for your MacBook Pro 15" Retina Mid 2012 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Ersatzteile für MacBook Pro 15" Retina Mid 2012:
MacBook Pro 15" Retina (Mid 2012) 2.7 GHz Logic Board
Replace a 2.7 GHz logic board (motherboard) compatible with the Mid 2012 MacBook Pro 15" Retina laptop. Includes RAM. Fix processing issues like unexpected shutdowns, reb...
MacBook Pro 15" Retina (Mid 2012) 2.3 GHz Logic Board
Replace a 2.3 GHz logic board (motherboard) compatible with the Mid 2012 MacBook Pro 15" Retina laptop. Includes RAM. Fix processing issues like unexpected shutdowns, reb...
MacBook Pro 15" Retina (Mid 2012) 2.6 GHz Logic Board
Replace a 2.6 GHz logic board (motherboard) compatible with the Mid 2012 MacBook Pro 15" Retina laptop. Included Ports: 2 Thunderbolt (Mini DisplayPort), USB 3.0. Fix pro...
Geräteinformation
On June 12, 2012 Apple announced the new 15" MacBook Pro with Retina display. It has an LED-backlit display with a 2880-by-1800 resolution at 220 pixels per inch. Like its regular display counterpart, the MBP Retina 15" has two USB 3 ports and an SDXC card slot but sacrifices the FireWire 800 and ethernet ports to include two ThunderBolt ports and an HDMI port. The MagSafe Port has also been replaced with the MagSafe 2 port allowing for a thinner case design.
The most common repairs with the 15" MacBook Pro Retina Mid 2012 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Mid 2012 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Mid 2012 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 15" Retina Display Mid 2012 earned a 1 out of 10 in iFixit's repairability assessment.
