Ersatzteile Mac MacBook Pro 15" Retina Case Components
Store
Du kennst dein Modell nicht? Mac identifizieren
MacBook Pro 15" Retina (Late 2013-Mid 2015) Lower Case
Replace a scratched or dented lower case compatible with a Late 2013 to Mid 2015 MacBook Pro 15" Retina laptop.
Von 49,99 $
MacBook Pro 15" Retina (Mid 2012-Early 2013) Trackpad / With Cable
Replace a scratched or malfunctioning trackpad compatible with a mid 2012 or early 2013 MacBook Pro 15" with Retina Display.
Von 71,99 $
MacBook Pro 15" Retina (Mid 2012-Early 2013) Upper Case Assembly
This assembly includes the backlit keyboard, trackpad assembly, and battery.
Von 81,99 $
MacBook Pro 15" Retina (Late 2016-2017) Display Gasket
Replace the elastic plastic gasket that fits around the outside edge of the display assembly for a Late 2016 or 2017 model 15" MacBook Pro with Retina Display.
9,99 $
MacBook Pro 15" Retina (Late 2013-Mid 2014) Upper Case Assembly / New / With Trackpad and Battery
Replace a damaged upper case.
Von 114,99 $
MacBook Pro 15" Retina (Late 2016/2017) Display Lower Edge Bezel Bracket
Replace a bent or damaged metal bracket that backs up the bezel at the bottom edge of the display assembly in a Late 2017 or 2017 model 15" MacBook Pro with Retina disp...
12,99 $
MacBook Pro 15" Retina (Mid 2012-Early 2013) Right I/O Board
Replace a damaged or corroded I/O board for your Mid 2012 or Early 2013 MacBook Pro 15" Retina and fix problems with display, and data connections. This assembly includes...
41,99 $
MacBook Pro 15" Retina (Late 2016-2017) Lower Case / New / Dark Gray
Replace a scratched or dented lower case compatible with a 2016 or 2017 model 15" MacBook Pro with Retina Display.
Von 49,99 $
MacBook Pro 15" Retina (Late 2016-2017) Trackpad / New / Dark Gray
Replace a damaged or malfunctioning trackpad compatible with a Late 2016 or 2017 model MacBook Pro 15" with Retina Display and Touch Bar.
Von 59,99 $
MacBook Pro 15" Retina (Late 2016-2017) Upper Case Assembly / A-Stock / Dark Gray
Replace a scratched or dented upper case or malfunctioning keyboard compatible with a 2016 or 2017 model 15" MacBook Pro with Retina Display.
Von 319,99 $
Angezeigte Artikel 1 - 10 von 11
Geräteinformation
In June 2012 Apple released the MacBook Pro 15" with a new Retina display with a 2880-by-1800 resolution. The Retina display models that followed the 2012 model vary by specifications and features.
The most common repairs with the 15" MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly. Choose a model for more specific information.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display repair guides for step-by-step instructions on how to make the fix.
