Ersatzteile Mac MacBook Pro 15" Unibody Late 2011 Hard Drives SATA
Store
Du kennst dein Modell nicht? Mac identifizieren
MacBook and MacBook Pro Unibody Plastic Feet / Part Only
Replace the black plastic feet on the lower case of your Unibody MacBook or MacBook Pro.
Von 4,99 $
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery / New / Fix Kit
Replacement battery, compatible with all Early 2011, Late 2011, and Mid 2012 15" Unibody MacBook Pros.
Von 84,99 $
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 $
Macbook Pro Unibody Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pr...
Von 9,99 $
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector.
Von 14,99 $
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
Von 114,99 $
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard and internal power button switch compatible with a Unibody A1286 15" MacBook Pro from mid 2009 to mid 2012.
19,99 $
Unibody Laptop Dual Drive
Increase the storage space in your laptop by replacing the optical drive with a second hard drive or SSD.
Von 24,99 $
1 TB SSD Hybrid 2.5" Hard Drive / Part Only
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive Hybrid, 5400 RPM / 2.5" wide x 9.5mm tall / 1 TB Unformatted
Von 84,99 $
Angezeigte Artikel 1 - 10 von 58
Geräteinformation
The Late 2011 version of MacBook Pro 15" Unibody is virtually identical to the Early 2011 model except for a CPU and graphics upgrade. It features a quad core Core i7 processor with PC3-10600 RAM. It also sports the new Thunderbolt standard allowing 10 Gbps transfer speeds in both directions.
The most common repairs with Late 2011 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (Late 2011) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 16 GB of RAM.
The Late 2011 model MacBook Pro 15" Unibody requires a Tri-point Y0 Screwdriver to remove the battery. Our battery repair kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody Late 2011 repair guides for step-by-step instructions on how to make the fix.
