MacBook Pro 15" Unibody Late 2011 Logic Boards
Grab a toolkit for your MacBook Pro 15" Unibody Late 2011 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Ersatzteile für MacBook Pro 15" Unibody Late 2011:
MacBook Pro 15" Unibody (Early 2011) 2.0 GHz Logic Board
Replace a 2.0 GHz Core i7 logic board (motherboard) compatible with the Early 2011 MacBook Pro 15" Unibody laptop. Included Ports: Thunderbolt (Mini DisplayPort), 1000Bas...
MacBook Pro 15" Unibody (Early 2011) 2.2 GHz Logic Board
Replace a 2.2 GHz logic board (motherboard) compatible with the Early 2011 MacBook Pro 15" Unibody laptop. Included Ports: Thunderbolt (Mini DisplayPort), 1000BaseT Ether...
MacBook Pro 15" Unibody (Early 2011) 2.3 GHz Logic Board
Replace a 2.3 GHz Core i7 logic board (motherboard) compatible with the Early 2011 MacBook Pro 15" Unibody laptop. Included Ports: Thunderbolt (Mini DisplayPort), 1000Bas...
MacBook Pro 15" Unibody (Late 2011) 2.2 GHz Logic Board
Replace a 2.2 GHz Core i7 logic board (motherboard) compatible with the Late 2011 MacBook Pro 15" Unibody laptop. Fix processing issues like unexpected shutdowns, reboots...
MacBook Pro 15" Unibody (Late 2011) 2.4 GHz Logic Board
Replace a 2.4 GHz Core i7 logic board (motherboard) compatible with the Late 2011 MacBook Pro 15" Unibody laptop. Fix processing issues like unexpected shutdowns, reboots...
Geräteinformation
The Late 2011 version of MacBook Pro 15" Unibody is virtually identical to the Early 2011 model except for a CPU and graphics upgrade. It features a quad core Core i7 processor with PC3-10600 RAM. It also sports the new Thunderbolt standard allowing 10 Gbps transfer speeds in both directions.
The most common repairs with Late 2011 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (Late 2011) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 16 GB of RAM.
The Late 2011 model MacBook Pro 15" Unibody requires a Tri-point Y0 Screwdriver to remove the battery. Our battery repair kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody Late 2011 repair guides for step-by-step instructions on how to make the fix.
