MacBook Pro 15" Unibody Mid 2009 Logic Boards
Grab a toolkit for your MacBook Pro 15" Unibody Mid 2009 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Ersatzteile für MacBook Pro 15" Unibody Mid 2009:
MacBook Pro 15" Unibody (Mid 2009) 2.66 GHz Logic Board
Replace a 2.66 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Pro 15" Unibody laptop. Includes attached heat sink and thermal paste. Fix processing is...
MacBook Pro 15" Unibody (Mid 2009) 2.8 GHz Logic Board
Replace a 2.8 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Pro 15" Unibody laptop (excluding the 2.53 GHz model). Included Ports: Mini DisplayPort, ...
MacBook Pro 15" Unibody (Mid 2009) 3.06 GHz Logic Board
Replace a 3.06 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Pro 15" Unibody laptop. Included Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire ...
Geräteinformation
The Mid 2009 version of MacBook Pro 15" Unibody features an SD card slot, dual graphics processors, two cooling fans, and a hefty internal battery that boasts up to 7 hours of life between charges. Note that this model excludes the 2.53 GHz processor machine released in Mid 2009. The 2.53 GHz machine has only one graphics processor and a single cooling fan.
The most common repairs with this Mid 2009 model MacBook Pro 15" Unibody laptop are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (Mid 2009) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
The Mid 2009 model MacBook Pro 15" Unibody requires a P6 Pentalobe screwdriver to remove the battery. Our battery repair kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody Mid 2009 repair guides for step-by-step instructions on how to make the fix.
