Ersatzteile Mac MacBook Pro 15" (Non-Unibody) Logic Boards
Store
Du kennst dein Modell nicht? Mac identifizieren
MacBook Pro 15" (Model A1150) 2.16 GHz Logic Board
2.16 GHz Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 400, USB 2.0
249,99 $
MacBook Pro 15" (Model A1150) 2 GHz Logic Board
2 GHz Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 400, USB 2.0
124,99 $
MacBook Pro 15" (Model A1150) 1.83 GHz Logic Board
249,99 $
MacBook Pro 15" (Model A1211) 2.16 GHz Logic Board
2.16 GHz Core 2 Duo Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0
249,99 $
MacBook Pro 15" (Model A1211) 2.33 GHz Logic Board
2.33 GHz Core 2 Duo Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0
149,99 $
MacBook Pro 15" (Model A1226) 2.2 GHz Logic Board
2.2 GHz Core 2 Duo Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0
249,99 $
MacBook Pro 15" (Model A1226) 2.4 GHz Logic Board
Replace a broken or damaged 2.4 GHz logic board in your Model A1226 MacBook Pro 15" with this part.
274,99 $
MacBook Pro 15" (Model A1260) 2.4 GHz Logic Board
2.4 GHz Core 2 Duo Penryn Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0 (high power)
299,99 $
MacBook Pro 15" (Model A1260) 2.5 GHz Logic Board
2.5 GHz Core 2 Duo Penryn Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0 (high power)
299,99 $
MacBook Pro 15" (Model A1226) 2.6 GHz Logic Board
2.6 GHz Core 2 Duo Santa Rosa Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0
349,99 $
Angezeigte Artikel 1 - 10 von 10
Geräteinformation
The MacBook Pro 15" replaced the Aluminum 15" and features Intel support and an integrated iSight camera.
All MacBook Pro 15" Non-Unibody models use PC2-5300 RAM. Two RAM slots means an easy memory upgrade! If storage is an issue, any 9.5mm SATA hard drive will expand your boundaries.
Heat has always been an issue for MacBook Pros. It's possible that a bad thermal sensor or fan will prevent the machine from booting.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Non-Unibody repair guides for step-by-step instructions on how to make the fix.
