Ersatzteile Mac MacBook Pro 15" (Non-Unibody) Rubber Feet
Store
Du kennst dein Modell nicht? Mac identifizieren
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 $
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
Von 114,99 $
500 GB SSD / Part Only
500 GB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 525 GB Unformatted
Von 139,99 $
1 TB SSD Hybrid 2.5" Hard Drive / Part Only
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive Hybrid, 5400 RPM / 2.5" wide x 9.5mm tall / 1 TB Unformatted
Von 84,99 $
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
9,99 $
250 GB SSD / Part Only
250 GB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 275 GB Unformatted
Von 94,99 $
MacBook Pro 15" Replacement Battery
Replace a dead or damaged battery in your MacBook Pro 15" with this part. This part is compatible with all 15" MacBook Pros (excluding Unibody).
59,99 $
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
24,99 $
1 TB SSD / Part Only
1 TB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 1050 GB Unformatted
Von 249,99 $
Angezeigte Artikel 1 - 10 von 132
Geräteinformation
The MacBook Pro 15" replaced the Aluminum 15" and features Intel support and an integrated iSight camera.
All MacBook Pro 15" Non-Unibody models use PC2-5300 RAM. Two RAM slots means an easy memory upgrade! If storage is an issue, any 9.5mm SATA hard drive will expand your boundaries.
Heat has always been an issue for MacBook Pros. It's possible that a bad thermal sensor or fan will prevent the machine from booting.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Non-Unibody repair guides for step-by-step instructions on how to make the fix.
