MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Right Fan
  • MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Right Fan
39,99 $
39,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
Erfolgreich repariert? Genial!
Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
Wir sind alle Genies
Artikelbeschreibung
Beschreibung
Beschreibung
Replace the right fan for your Late 2008 through Mid 2012 Unibody 15" MacBook Pro (excluding Mid 2009 2.53 GHz) with this part. This part includes the fan and its surrounding metal bracket.
Kompatibilität
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
2.93 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2009
2.66 GHz
2.8 GHz
3.06 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
MacBook Pro 15" Unibody Mid 2012
2.3 GHz
2.6 GHz
2.7 GHz
3 weitere Geräte zeigen
Reparatur-Geschichten
Nutzeravatar
Baron's Story Photo #898994
Mein Problem
In photo old fan on left, replacement (used fan) on right. The old fan was slowing down 0-200 rpm when it should have been going 3K rpm. It was making a lot of noise like maybe the bearings were shot.
Meine Reparatur
I purchased a used Right Fan from iFixit for my Mid-2010 MacBook Pro since it still cam with a lifet . . .
Nutzeravatar
Mein Problem
to much noise to produce music and video.
Meine Reparatur
it went very well.
Mein Rat
Just use the correct tools to repair your devices and do it yourself, it's funny
Nutzeravatar
Mein Problem
Had to change the battery in my 5 year old MacBook Pro 15"
Meine Reparatur
The service and delivery speed was top notch!
Installed the new battery I got from Ifixit.
What bothers me is that the new battery is not as good as I expected.
It drains fairly quickly, almost the same speed as the old one.
The situation i . . .
Nutzeravatar
Mein Problem
The fan is so loud. Sound like the fan is ripping itself apart and my MacBook Pro got very warm
Meine Reparatur
Following the instruction. It was quite easy and fast.
Mein Rat
Get all the tool first
Nutzeravatar
Mein Problem
The fans on my MacbookPro had been running constantly due to some software that seemed to need 1 CPU to run constantly to check web pages. After finally figuring out which software to trash and reducing use of the fan, the wear and tear of this bad software took its toll and eventually the fans sta . . .
Nutzeravatar
Mein Problem
My old fan was rattling and I had to hit my Macbook in order to stop it.
Meine Reparatur
The fan is probably one of the easiest things to replace.
Mein Rat
I wish I had gone to ifixit before. Real quick and easy repair. Will buy from again.
Nutzeravatar
Mein Problem
My brother's Macbook Pro was making some interesting sounds on top of overheating. We did some research and came across ifixit.com how-to articles. From there, I ordered the fans (used), and the problem was fixed!
Meine Reparatur
Removing and replacing the right and left fans (Macbook Pro 15 mid-2009 2.8 GHz model) . . .
Nutzeravatar
Mein Problem
fans started making grinding noise so had to replace
Meine Reparatur
No problems. Easy and didn't take long
Mein Rat
Make sure to clean out the intake grills before you switch up your fans, and it's probably a good idea to start cleaning out that dust every 6 months or so
Nutzeravatar
Mein Problem
Mis ventiladores hacían muchísimo ruido, ni se iba con lubricante especial para ventiladores.
Meine Reparatur
Ventiladores como nuevo. Silencio absoluto. Paquete bien protegido. Atención, servicio y rapidez de entrega inmejorable.
Valoración 12 sobre 10.
Mein Rat
Lamento que en su página en Europa, no tengan existencias, . . .
Nutzeravatar
Mein Problem
leftFAN noises and damaged
rightFAN was ok but i want to change it
Meine Reparatur
All perfect, except for the rightFAN. I can't unscrew the old one, the screw is locked!
Mein Rat
nn
Mehr anzeigen
