Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 15" (Model A1150) Display Assembly
  • MacBook Pro 15" (Model A1150) Display Assembly
179,99 $
179,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 15" (Model A1150) replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
An aging or battered laptop display may suffer a flickering image, dead pixels, or a dim backlight. Surface scratches can further degrade the image and a dented or warped case may pinch the display causing bright spots. Eliminate these flaws with a replacement LCD display assembly. Our displays are individually tested and guaranteed to function perfectly.
Die Einheit enthält
Die Einheit enthält
  • 1440 x 900 15.4" LCD Screen
  • Display Cover
  • Bezel
  • iSight Camera
  • Clutch Hinges
  • Display Inverter
  • Wi-Fi Antenna
  • Display Data Cables
Kompatibilität
Kompatibilität
  • MacBook Pro 15" A1150
Eigenschaften
Eigenschaften
Part #:
661-3950
Resolution:
1440x900
Diagonal Size:
15.4"
Kompatibilität
MacBook Pro 15" Core Duo Model A1150
A1150 (EMC 2101) 1.83 GHz
A1150 (EMC 2101) 2 GHz
A1150 (EMC 2101) 2.16 GHz
