Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 15" (Model A1211) Display Assembly
  • MacBook Pro 15" (Model A1211) Display Assembly
299,99 $
299,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 15" (Model A1211) replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
An aging or battered laptop display may suffer a flickering image, dead pixels, or a dim backlight. Surface scratches can further degrade the image and a dented or warped case may pinch the display causing bright spots. Eliminate these flaws with a replacement LCD display assembly. Our displays are individually tested and guaranteed to function perfectly.
Die Einheit enthält
Die Einheit enthält
  • 1440 x 900 pixel 15.4" LCD Screen
  • Display Cover
  • Bezel
  • iSight Camera
  • Clutch Hinges
  • Display Inverter
  • Wi-Fi Antenna
  • Display Data Cables
Kompatibilität
Kompatibilität
  • MacBook Pro 15" A1211
Eigenschaften
Eigenschaften
Part #:
661-4238, 661-4239
Resolution:
1440x900
Diagonal Size:
15.4"
Kompatibilität
MacBook Pro 15" Core 2 Duo Model A1211
A1211 (EMC 2120) 2.16 GHz
A1211 (EMC 2120) 2.33 GHz
Reparatur-Geschichten
Nutzeravatar
Mein Problem
Original display had deteriorated. Approx 50 % usable. Replaceing just LCD seemed too tricky, so ordered entire assembly.
Meine Reparatur
Very smoothly and straightforward. Photos were very helpful. A couple of connectors were better identifiable from photo of removed piece.
Mein Rat
Read instructions thru to end first. . . .
