Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 15" (Model A1260) Display Assembly
  • MacBook Pro 15" (Model A1260) Display Assembly
149,99 $
149,99 $
Das Essential Electronics Toolkit
Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
Jetzt kaufen
Jetzt kaufen
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 15" (Model A1260) Display Assembly replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
An aging or battered laptop display may suffer a flickering image, dead pixels, or a dim backlight. Surface scratches can further degrade the image and a dented or warped case may pinch the display causing bright spots. Eliminate these flaws with a replacement LCD display assembly. Our displays are individually tested and guaranteed to function perfectly.
Die Einheit enthält
Die Einheit enthält
  • 1440 x 900 pixel 15.4" LCD Screen
  • Display Cover
  • Bezel
  • iSight Camera
  • Clutch Hinges
  • Display Inverter
  • Wi-Fi Antenna
  • Display Data Cables
Kompatibilität
Kompatibilität
  • MacBook Pro 15" A1260 Early 2008
Eigenschaften
Eigenschaften
Part #:
661-4609, 661-4610
Size:
15.4"
Resolution:
1440x900
Kompatibilität
MacBook Pro 15" Core 2 Duo Models A1226 & A1260
A1260 (EMC 2198) 2.4 GHz (Penryn)
A1260 (EMC 2198) 2.5 GHz (Penryn)
A1260 (EMC 2198) 2.6 GHz (Penryn)
Reparatur-Geschichten
Nutzeravatar
Susan's Story Photo #369372
Susan's Story Photo #369377
Susan's Story Photo #369378
Mein Problem
My Macbook Pro is early 2008. Right side of screen started striping, then eventually went black. Apple wanted $600 and time to find the part. I found it on ifixit for $150. I elected to get the display AND housing, rather than take apart the display housing and pull out the display screen (soldering . . .
Nutzeravatar
Mein Problem
I've already known how to substitute a mac book pro's display due an older problem with my iSight.
Meine Reparatur
The repair went pretty good, I didn't get any kind of problem.
Mein Rat
be careful while doing this operation.
