Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 15" Retina (Late 2016-2017) Battery
  • MacBook Pro 15" Retina (Late 2016-2017) Battery / Fix Kit
  • MacBook Pro 15" Retina (Late 2016-2017) Battery / Part Only
  • 360°
360
139,99 $
139,99 $
Das Essential Electronics Toolkit
Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
Jetzt kaufen
Jetzt kaufen
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 15" Retina (Late 2016-2017) replacement battery fix kit includes all the parts, tools, and adhesive you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 6340 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop's lifespan, extend it with this new replacement battery compatible with Late 2016 to 2017 MacBook Pro 15" Retina. Factory-installed MacBook Pro batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Die Einheit enthält
Die Einheit enthält
  • New replacement battery compatible with a MacBook Pro 15" Retina (Late 2016/Mid 2017)
  • Installation adhesive
Kit Inhalt
Kit Inhalt
Kompatibilität
Kompatibilität
  • MacBook Pro 15" Retina A1707 Late 2016 to 2017
Eigenschaften
Eigenschaften
Model #:
A1820
Watt Hours:
76 Wh
Voltage:
11.4 V
Milliamp Hours:
6667 mAh
Manufacturer:
Aftermarket
Kompatibilität
MacBook Pro 15" Touch Bar 2017
A1707 (EMC 3162) 2.8 GHz
A1707 (EMC 3162) 2.9 GHz
A1707 (EMC 3162) 3.1 GHz
MacBook Pro 15" Touch Bar Late 2016
A1707 (EMC 3072) 2.6 GHz (Touch Bar Late 2016)
A1707 (EMC 3072) 2.7 GHz (Touch Bar Late 2016)
A1707 (EMC 3072) 2.9 GHz (Touch Bar Late 2016)
Kundenbewertungen
