MacBook Pro 15" Retina (Mid 2012-Early 2013) Left Fan
  • MacBook Pro 15" Retina (Mid 2012-Early 2013) Left Fan
49,99 $
49,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Artikelbeschreibung
Beschreibung
Beschreibung
Replace a defective or noisy left fan. This part is compatible with a Mid 2012 or Early 2013 MacBook Pro 15" Retina laptop.
Kompatibilität
Reparatur-Geschichten
Mein Problem
My MacBook Pro was making a very loud and vibrating sound from the left fan.
Meine Reparatur
Everything went fine. It was easy and once I turned on the computer I heard that everything was fixed.
Mein Rat
Just remember to slide the connector on step 7. I tried to lift it, but you could damage the computer. Just slide it and . . .
Mein Problem
Left fan went out in my MacBook Pro Retina 15". I was out of warranty last fall.
Meine Reparatur
I'd already been inside my computer to add a larger SSD drive and have opened it up to clean it out so I felt comfortable with the repair after looking at the repair guide. I took paper cups and marked them all with th . . .
Mein Problem
The battery in my 4 year old MacBook Pro was acting up - erratically switching off although still 40% full, diminishing uptime, and telling me it needed "servicing". Since there is no Apple store in this part of the world, I went to a certified Apple repair shop where they told me "You can leave you . . .
Mein Problem
Noisy Fan: worn off ball bearing
Meine Reparatur
Easy, straight forward
Mein Rat
Can always use a tape to assist inserting the ribbon cable if you do not have any tool
Mein Problem
The left fan on my Macbook Pro suddenly started emitting a wicked loud noise. I thought the computer was about to explode. But the computer was working fine, and it took me a few minutes to isolate the fan as the source of the terrors.
Meine Reparatur
The repair kit came insanely fast--like a whole week earlier than . . .
Mein Problem
The left fan on my Mac got louder after being dropped. It was just enough to be noticeable in a quiet room.
Meine Reparatur
The repair went well, except, I broke and misplaced the flat flex cable connector retention clip. It wasn't clear from the instructions what direction the clip moved to open to release the fan . . .
Mein Problem
All of a sudden when turning on my macbook the left side of the unit was extremely loud and I could tell it was a fan since the system still worked fine. I wasn't sure if the fan was shot or if it just needed to be cleaned, but since I didn't have a P5 Pentalobe screwdriver yet I decided to order on . . .
Mehr anzeigen
