Ersatzteile Mac 17" Unibody Early 2011 Rubber Feet
Store
Du kennst dein Modell nicht? Mac identifizieren
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 $
Macbook Pro Unibody Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pr...
Von 9,99 $
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 $
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
Von 89,99 $
500 GB SSD / Part Only
500 GB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 525 GB Unformatted
Von 109,99 $
PC3-10600 8 GB RAM Chip
Replace or upgrade the RAM in your desktop, laptop, or game console for faster performance. Low Profile / 204 pin / 1333 MHz
Von 49,99 $
Apple MagSafe 1 AC Adapter / 85 W / AC Adapter End / New
Replace a broken or damaged Apple MagSage 1 AC adapter with this part.
Von 39,99 $
Unibody Laptop Dual Drive
Increase the storage space in your laptop by replacing the optical drive with a second hard drive or SSD.
Von 24,99 $
PC3-10600 4 GB RAM Chip
Add or upgrade the RAM in your computer. 4 GB / PC3-10600 / Low Profile / 204 pin, 1333 MHz
Von 19,99 $
MacBook Pro 17" Unibody (Early-Late 2011) Replacement Battery / Fix Kit
Aftermarket replacement battery, compatible with all Early 2011 17" Unibody MacBook Pros and all Late 2011 17" Unibody MacBook Pros.
Von 94,99 $
Angezeigte Artikel 1 - 10 von 38
Geräteinformation
Introduced in February 2011, this model MacBook Pro 17" Unibody laptop features Core i7 processor, dual graphics processors, an integrated FaceTime HD camera, an 1920x1200 display, AirPort Extreme (802.11a/b/g/n), Bluetooth 2.1+EDR, Gigabit Ethernet, one Firewire "800" port, three USB 2.0 ports, separate audio in and out ports, an ExpressCard/34 expansion slot, and a new "Thunderbolt" port that is backwards compatible with Mini DisplayPort.
The most common repairs with a 17" MacBook Pro Unibody Early 2011 are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 17" Unibody (Early 2011) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 16 GB of RAM.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 17" Unibody Early 2011 repair guides for step-by-step instructions on how to make the fix.
