Repariere deine Sachen
Recht auf Reparatur
Store
Parts Mac MacBook Pro MacBook Pro 17" MacBook Pro 17" Unibody Logic Boards
Store
Grab a toolkit for your MacBook Pro 17" Unibody model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Du kennst dein Modell nicht? Mac identifizieren
MacBook Pro 17" Unibody (Mid 2009) 3.06 GHz Logic Board
Replace a 3.06 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Pro 17" Unibody laptop. Fix processing issues like unexpected shutdowns, reboots, or wat...
449,99 $
MacBook Pro 17" Unibody (Early 2011) 2.2 GHz Logic Board
Replace a 2.2 GHz logic board (motherboard) compatible with the Early 2011 MacBook Pro 17" Unibody laptop. Fix processing issues like unexpected shutdowns, reboots, or wa...
508,99 $
MacBook Pro 17" Unibody (Early 2011) 2.3 GHz Logic Board
Replace a 2.3 GHz logic board (motherboard) compatible with the Early 2011 MacBook Pro 17" Unibody laptop. Includes left side ports. Fix processing issues like unexpected...
549,99 $
MacBook Pro 17" Unibody (Late 2011) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Late 2011 MacBook Pro 17" laptop. Fix processing issues like unexpected shutdowns, reboots, or water damag...
499,99 $
no image
MacBook Pro 17" Unibody (Late 2011) 2.5 GHz Logic Board
Replace a 2.5 GHz logic board (motherboard) compatible with the Late 2011 MacBook Pro 17" Unibody laptop. Includes left side ports. Fix processing issues like unexpected ...
549,99 $
MacBook Pro 17" Unibody (Mid 2010) 2.53 GHz Logic Board
Replace a 2.53 GHz Core i5 logic board (motherboard) compatible with the model A1297 Mid 2010 17" Unibody MacBook Pro laptop. Fix processing issues like unexpected shutdo...
249,99 $
MacBook Pro 17" Unibody (Mid 2010) 2.66 GHz Logic Board
Replace a damaged or malfunctioning 2.66 GHz Core i7 logic board in a model A1297 17" Unibody MacBook Pro from 2010. Fix processing issues like unexpected shutdowns, rebo...
533,99 $
MacBook Pro 17" Unibody (Early 2009) 2.66 GHz Logic Board
Replace a 2.66 GHz logic board (motherboard) compatible with the Early 2009 MacBook Pro 17" Unibody laptop. Included Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire...
449,99 $
MacBook Pro 17" Unibody (Early 2009) 2.93 GHz Logic Board
Replace a 2.93 GHz logic board (motherboard) compatible with the Early 2009 MacBook Pro 17" Unibody laptop. Included Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire...
499,99 $
MacBook Pro 17" Unibody (Mid 2009) 2.8 GHz Logic Board
Replace a 2.8 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Pro 17" laptop. Fix processing issues like unexpected shutdowns, reboots, or water damage...
99,99 $
Angezeigte Artikel 1 - 10 von 10
Geräteinformation
The MacBook Pro 17" Unibody, announced in January of 2009 has an aluminum case like the laptops before it, however the case is machined out of a single block of aluminum. The Unibody revision also introduced some new features for Apple laptops: dual video cards (one for regular use, one for graphics intensive applications), the Mini DisplayPort (which replaced the full-size DVI display connector), and larger hard drive and RAM capacities.
The most common repairs with the Unibody model 17" MacBook Pro laptops are replacing a dead battery, replacing a malfunctioning fan, and upgrading the hard drive or RAM.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 17" Unibody repair guides for step-by-step instructions on how to make the fix.
