Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 17" (Model A1261 Hi-Res) LCD LED Panel
  • MacBook Pro 17" (Model A1261 Hi-Res) LCD LED Panel
219,99 $
219,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
Replace a damaged or malfunctioning 17" 1920 x 1200 LCD panel in your MacBook Pro 17" (Model A1261 Hi-Res) laptop.
This LCD panel can restore dead pixels, fix color bleeding, and eliminate lines in your display image as well as restore a dim or dead backlight.
Kompatibilität
Kompatibilität
  • 2.5 or 2.6 GHz (Model A1261) 17" MacBook Pros with 1920x1200 resolution
Eigenschaften
Eigenschaften
Resolution:
1920 x 1200
Diagonal Size:
17"
Kompatibilität
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
A1261 (EMC 2199) 2.5 GHz (Penryn)
A1261 (EMC 2199) 2.6 GHz (Penryn)
Reparatur-Geschichten
Nutzeravatar
Mein Problem
LCD was bad on a Macbook Pro A1261, ordered new screen.
Meine Reparatur
Took everything apart only to realize I had ordered the wrong screen. Take note technicians, check your connectors on new parts before breaking everything down. And read everything about the part you are ordering carefully.
Mein Rat
iFixit team respond . . .
Nutzeravatar
Mein Problem
in quick succession I broke the LCD on the 17" Macbook Pro due to sloppy handling, and I shattered the glass front on my iPhone 5.
Both were not yet at the end of their life/usefulness so I decided to fix both myself.
Meine Reparatur
things went pretty well. Finished both repairs in about 3 hours (while watching . . .
Nutzeravatar
Mein Problem
My 1 year old son had smashed my MacBook Pro screen and it was damaged for more then a year. I inquired at the local Apple Store and was shocked to know that the LED display would cost me around 1000$, it was so expensive that I thought I would never be able to repair it, until ifixit stepped in my . . .
Nutzeravatar
Mein Problem
Broken LCD on my macbook pro
Meine Reparatur
Ordered part to fix. But it was damaged:( so i called got a replacement. Great CS by the way. Well.. I got ancy and started to take apart the laptop and found out that i ordered the wrong part.. Called back and the 1st replacement was already sent. So i ordered the right . . .
Mehr anzeigen
