MacBook Pro 17" (Model A1261) Left Fan
  • MacBook Pro 17" (Model A1261) Left Fan
39,99 $
39,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
iPhone Akku Fix Kits
Nur $29.99
Buy Now
Nur $29.99
Buy Now
Artikelbeschreibung
Beschreibung
Beschreibung
Replace a malfunctioning or noisy fan compatible with a Model A1261 17" MacBook Pro.
If your screen is facing you, this is the fan on the left side of the machine.
Looking for the Right Fan?
Kompatibilität
Kompatibilität
  • MacBook Pro 17" A1261 Early 2008 and Late 2008
Eigenschaften
Eigenschaften
Part #:
922-8395
Kompatibilität
Reparatur-Geschichten
Nutzeravatar
Mein Problem
Laptop was running really hot. Fan control utility showed left fan was not running. 0 RPM.
Meine Reparatur
Outstanding. Followed repair guide easily
Mein Rat
Add recommendation for cleaning dust from fan exit ports. Remove both fans and clean dust. Tooth picks and Q-tips worked
Add link in guide for removing and reconnec . . .
Nutzeravatar
Mein Problem
Fan was noisy
Meine Reparatur
Part came in when expected and was correct. Used the Ifixit guide to tear down and replace the fan which went with no issue. Did have an issue with the Mac's top case where the front inside screw attachment brackets spot welds failed (not happy with Apple's quality here), but everythi . . .
Nutzeravatar
Mein Problem
The right fan had become very loud.
Meine Reparatur
I first tried to just clean the fan blades, as others on the web have noted. But the blades are fragile and I managed to break one off while cleaning. Even though I was being quite careful.
So I bought a new fan. I decided to replace both fans as both were dirty . . .
Nutzeravatar
Mein Problem
Left fan was noisy enough to be heard from the next room.
Meine Reparatur
First try was on the previous weekend -- I used the guide to take out the noisy fan, disassembled it, cleaned it, and applied some lube. Put everything back together, fired it up, and there was blessed silence.
For ten minutes.
Ten min . . .
Nutzeravatar
Mein Problem
Funny thing. The sensors acted weird - it even wrote messages by itself.
Meine Reparatur
Same procedure as always - just follow the tutorial.
Mein Rat
After changing the iPhone display, the phone might not start up with just the backlight on. Don't panic, just do a forced reboot (Home + Power button until you see the apple)
Nutzeravatar
Mein Problem
Noisy fans in the MacBook Pro made using the laptop nearly impossible. The high pitch whiny rattle was loud and obnoxious at times and what Apple wanted to charge to fix it was like taking out a second mortgage. So when I found iFixit with guides on "how to" I thought why not?
Meine Reparatur
The guides didn't make . . .
Nutzeravatar
Mein Problem
Left fan was making loud grinding sound, so both fans replaced to avoid future problems with right fan
Meine Reparatur
Instructions were very good with easy step by step procedures.
Mein Rat
FOLLOW THE INSTRUCTIONS, make sure the i-sight cable and converter cables are properly connected before closing the case. Use something . . .
Nutzeravatar
Mein Problem
The MacBook was too warm!
Meine Reparatur
All OK! It was necessary about 8 housr of work (disassembly and re-assembly the MacBook)
Mein Rat
Mehr anzeigen
