Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 17" Unibody (Early-Late 2011) Battery
  • MacBook Pro 17" Unibody (Early-Late 2011) Battery / Fix Kit
  • MacBook Pro 17" Unibody (Early-Late 2011) Battery / Part Only
  • 360°
360
99,99 $
99,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 17" Unibody (Early-Late 2011) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 12530 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
Battery degradation is an inevitable part of your laptop’s lifespan, extend it with this new replacement battery compatible with Early to Late 2011 MacBook Pro 17" Unibody. Factory-installed MacBook Pro batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kit Inhalt
Kit Inhalt
Kompatibilität
Kompatibilität
  • MacBook Pro 17" Unibody A1297 Early 2011 to Late 2011
Eigenschaften
Eigenschaften
Model #:
A1383
Watt Hours:
95 Wh
Voltage:
10.95 V
Milliamp Hours:
13190 mAh
Manufacturer:
Aftermarket
Kompatibilität
A1297 (EMC 2352-1) 2.2 GHz (Early 2011)
A1297 (EMC 2352-1) 2.3 GHz (Early 2011)
A1297 (EMC 2564) 2.4 GHz (Late 2011)
A1297 (EMC 2564) 2.5 GHz (Late 2011)
Reparatur-Geschichten
Nutzeravatar
Mein Problem
i had a 5 years old battery
Meine Reparatur
i did not do it myself i went to a local electronics shop, the whole thing went great
Mein Rat
the battery is definitely a better replacement but of course it's not gonna be as great as a new MacBook pro battery
