MacBook Pro 5,1 Case Components
Grab a toolkit for your MacBook Pro 5,1 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Wähle dein MacBook Pro 5,1 Modell:
Ersatzteile für MacBook Pro 5,1:
MacBook Pro 15" Unibody (Late 2008-Early 2009) Upper Case
Replace an Upper Case compatible with the MacBook Pro 15" Unibody A1286 Late 2008 to Early 2009 laptop. Includes the backlit keyboard, trackpad, IR sensor, and battery le...
MacBook Pro 15" Unibody (Late 2008-Early 2009) Lower Case
Replace a scratched or dented lower case.
MacBook Pro 15" Unibody (Late 2008-Early 2009) Access Door
Replace a scratched or dented battery access door on your laptop.
MacBook Pro 15" Unibody (Late 2008-Early 2009) Mid Wall
Replace the center bracing inside your machine.
MacBook Pro 15" Unibody (Late 2008-Early 2009) Trackpad
Replace a trackpad compatible with the Late 2008 or Early 2009 model A1286 MacBook Pro 15" Unibody laptop. Part #922-9008.
Geräteinformation
Released in October of 2008, the MacBook Pro 15" Unibody looks very distinct from previous MacBook laptop models. Unibody MacBook Pro laptops have a case machined out of a single block of aluminum, dual video cards (one for regular use, one for graphics intensive applications), the Mini DisplayPort (which replaced the full-size DVI display connector), and larger hard drive and RAM capacities.
The most common repairs with the Unibody 2008 and Early 2009 model 15 inch MacBook Pro laptops are replacing a dead battery or upgrading the hard drive or RAM.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody repair guides for step-by-step instructions on how to make the fix.
