Repariere deine Sachen
Recht auf Reparatur
Store
Parts Mac MacBook Pro MacBook Pro Unibody Case Components
Store
Grab a toolkit for your MacBook Pro Unibody model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Du kennst dein Modell nicht? Mac identifizieren
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a scratched or malfunctioning trackpad in your Mid 2009 to Mid 2012 13” Unibody MacBook Pro model A1278 laptop. Part #922-9063, 922-9525, 922-9773.
Von 49,99 $
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a trackpad compatible with the Mid 2009 to Mid 2012 model A1286 MacBook Pro 15 inch Unibody laptop. Part #922-9035, 922-9306, 922-9749.
59,99 $
MacBook Pro 13" Unibody Lower Case
Replace a scratched or bent lower case panel on your laptop.
Von 49,99 $
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case / A-Stock / With Keyboard
Replace an upper case assembly compatible with the model A1278 Early 2011 to Mid 2012 MacBook Pro 13 inch Unibody laptop.
Von 28,99 $
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
Replace an upper case, backlit keyboard, and battery level indicator assembly compatible with the Early 2011 to Mid 2012 15 inch MacBook Pro Unibody laptop.
Von 129,99 $
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Bracket
Replace the bracket that houses the Airport/Bluetooth board compatible with the Early 2011 to Mid 2012 A1278 Unibody 13 inch MacBook Pro laptop. Part #076-1381.
5,99 $
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Bracket
Replace a bracket that houses the Airport and Bluetooth board compatible with the Early 2011 to Mid 2012 Unibody 15 inch MacBook Pro laptop. Part #076-1380.
19,99 $
MacBook Pro 17" Unibody (Early 2009-Late 2011) Trackpad
Replace a trackpad compatible with the Early 2009 to Late 2011 MacBook Pro 17 inch Unibody laptop. Part #922-9009, 922-9826.
59,99 $
MacBook Pro 15" Unibody (Mid 2009) Upper Case
Replace an upper case, backlit keyboard, and battery level indicator assembly compatible with the Mid 2009 model A1286 MacBook Pro 15 inch Unibody laptop.
Von 14,99 $
Angezeigte Artikel 1 - 10 von 26
Geräteinformation
Apple released the MacBook Pro Unibody with a new aluminum case drilled from a single aluminum brick. This provides greater structural integrity and less manufacturing waste. A buttonless click trackpad with multitouch capability is also a new feature of these machines.
Select your version above for parts and support!
