MacBook Pro Heat Sinks
Grab a toolkit for your MacBook Pro model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Wähle dein MacBook Pro Modell:
Ersatzteile für MacBook Pro:
MacBook Pro 15" Retina (Late 2013-Mid 2015, Dual Graphics) Heat Sink
This part attaches to the processor and helps dissipate heat.
MacBook Pro 15" Retina (Mid 2012-Early 2013) Heat Sink
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Heat Sink
MacBook Pro 13" Retina (Late 2012-Early 2013) Heat Sink
MacBook Pro 15" Unibody (Early 2011-Late 2011) Small Heat Sinks
Replace a broken or malfunctioning MacBook Pro 15" Unibody small heat sink.
MacBook Pro 13" Retina Fan Ducts
Replace the elastic gaskets that direct the airflow from the fans to the heat sink compatible with the A1425 model Retina 13 inch MacBook Pro laptop. Part #923-0228.
MacBook Pro 17" Unibody (Early-Mid 2009) Heat Sink
MacBook Pro 13" Retina (Late 2013-Early 2015) Heat Sink
Replace a damaged heat sink. This part dissipates heat generated by your computer's processors.
MacBook Pro 13" Unibody (Mid 2010) Heat Sink
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Heat Sink
Replace a damaged heat sink compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar. The heat sink dissipates heat from the CPU.
Geräteinformation
Catering to the working professional, the MacBook Pro is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
We sell dozens of MacBook Pro upgrades and repair parts. It's easy, fast, and safe to max out your machine! Two RAM slots allow for an easy memory boost. Need more storage? Drop in a larger-capacity 500 GB 7200 RPM 9.5mm SATA hard drive for some much-needed space as well as speed. An 85-watt MagSafe adapter will keep your machine juiced through even the most power demanding processes.
Select your version above for parts and assistance!
