Artikelbeschreibung
Beschreibung
This MacBook Unibody (A1278) replacement battery is what you need to bring your dead laptop back to life!
- 100% factory tested.
- Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 3960 mAh.
- Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
- Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop's lifespan, extend it with this new replacement battery compatible with MacBook Unibody (Model A1278). Factory-installed MacBook 13" Unibody (Late 2008) batteries are rated to last 500 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kompatibilität
- MacBook 13" Unibody A1278 2 GHz and 2.4 GHz
Eigenschaften
Kundenbewertungen
